Need Help. Car will not start
Old Apr 3, 2004 | 02:33 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
I put together a 383, TF heads 219 cam SR and LS1 25lbs injectors. My timing is right. Valves are adjusted right, I have spark and I have fuel. my plugs are dripping wet. It sounds like it wants to fire but it wont. Then when I let off I get a pop in the exhaust. triple checked the timing and it was all good. Any ideas?
89 Formula. Chip has been burned for the injectors.
Old Apr 3, 2004 | 05:23 PM
Kat's Avatar
Kat
Car: Camaro Vert
Engine: 355 HSR
Transmission: A4
Axle/Gears: 3.73 S60
The distributor could be 180* out or the CTS could be messed up.. Hook up a scanner to it and see what the puter is doing when you are trying to start it.
Kat
Old Apr 4, 2004 | 02:09 PM
formula350_87's Avatar
IAC might have been set wrong way. As a result throttle air bypass does not provide enough air. Can you tap gas pedal when cranking? Does it make a difference? If so - it's IAC.
Another possibility - bad MAF or MAP sensors.
Old Apr 4, 2004 | 03:17 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Everything worked perfect on the car before I put the new shortblock in and Injectors. Everything else is off the new combo. I am now thinking about the air situation. It sounded like it wanted to fire but then BAM out the back. I want to redo the valves and open the throttle a little more just to get it going. I hate flooding it out with a new motor.
Old Apr 5, 2004 | 02:33 AM
porkyzilla's Avatar
Car: 89 iroc-z 5.7tpi 350,
Engine: 5.7tpi 350,
its an easy one tripple check the plugs and wires make sure you didnt mix them up. i can scan in....since they are so close follow the wire by hand to the plug....
Old Apr 5, 2004 | 12:27 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
No matter how many times I checke dthe distributor it always perfect then today I said lets try again and found TDC and said lord if you love me I'll be 180 out. Shure ebough 180 out. Yurned it around fired in 3 secs with 55 PSI Oil and perfect idle
midge54
Dec 27, 2019 04:14 PM
Wade787b
Sep 29, 2015 01:15 PM
killer777
Aug 8, 2015 02:47 PM
