What is a good cam for 86 TPI
Old Apr 11, 2004 | 10:53 AM
jrdind's Avatar
Has anyone replaced their cam on a 86 TPI. I have read that the stock cam is responsible for a 20 hp loss. Would like to change to a cam that increases low to midrange torque. Thanks
Old Apr 11, 2004 | 11:20 AM
KYL98's Avatar
Car: 1991 Z28
Ill assume since it's an 86, that its a 305 right?? If you want a cheap alternative, Id find a used LT1 cam, or maybe a ZZ4 cam.....if you want more or better advice, give COMP cams a call or email. Hope this helps......
Old Apr 11, 2004 | 12:44 PM
jrdind's Avatar
cam change
You're right its a 305. Has anyone done a dyno on the difference between stock and the zz4 cam.
Old Apr 11, 2004 | 01:47 PM
biff85ta's Avatar
Car: 04 Vette
Those cams won't work in an 86 because it has a flat tappet not a roller cam.
Old Apr 11, 2004 | 06:53 PM
mikobu3's Avatar
comp extreme energy #256 212 - 218 449-456 112lsa
thats your baby you want for the 1986 305 tpi
Old Apr 11, 2004 | 07:28 PM
jrdind's Avatar
Cam
Have you tried the comp cam, if so do you know what the difference was in hp. Thanks
Old Apr 11, 2004 | 07:32 PM
mmcdjs's Avatar
Car: 1991 Pontiac Firebird
Engine: 3.1 V6
what do you think of this one: comp cam XE268H
224/230 @ .050 268/280 advertised duration 477/480 lift 110 lobe sep.
I'm looking at putting that one into my 1992 firebird SD system.
Old Apr 11, 2004 | 08:31 PM
injdinjn's Avatar
Car: 1986 Grand Prix TPI
Transmission: 200 4R
Way too big for a 305 unless there is something about the heads you arent telling us.
Old Apr 12, 2004 | 01:54 AM
iceman02's Avatar
Car: 91Z28 L98
Engine: HSR 350
Transmission: Goebel 700R4
I have that cam in my '86 (non-roller 350), the XE268 that is. Too much for a mild 305. You probably need to list a little more info about this '92 you mention though. Best bet would to be to call Comp Cams, get their recommendation, and then ask questions here to other people who are running whatever they recommend.
Old Apr 12, 2004 | 02:27 AM
jfreeman74's Avatar
Car: 1985 Iroc-Z
Engine: 1 BA 305 TPI
Transmission: Probuilt 700R4 - 2800 Stall Midwest
The 212/218 114LSA would be good for a mild 305. I am looking at the 218/224 for my setup. I was considering the 224/230 but I don't want it to sound like a racecar. I'm not sure how much lope I would have with that cam. But I will have a heavily modded 305 with heads and possible aftermarket intake.
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
camaro71633
Sep 1, 2015 10:24 AM
Sanjay
Aug 12, 2015 03:41 PM
squiggy2
Aug 9, 2015 09:30 PM
drathaar907
Aug 6, 2015 04:20 PM
