performance parts for 305
Old Apr 11, 2004 | 06:24 PM
Yield's Avatar
Car: 91 Camaro Z28
Engine: 5.0 305 TPI
Transmission: Automatic
ive just started learning about cars in general and my 91 Z is my first car, so i was wondering what i could do to my car to get a lil more performance out of it...hell if a mach 1 can get 305 horses out of a 4.6 litre engine surely i can get just as much out of mine.
Old Apr 11, 2004 | 09:02 PM
nikh23's Avatar
Car: 88 IROC Convertible
Transmission: Raptor 700
first off welcome to the boards. secondly lets start with what kind of car you have, how many miles are on it, and what you've done so far. Once we've determined that you can start considering what you would like to do to your car.
first if you have just bought this car and don't know much about its history, the best thing you could do for it would be to perform a full tuneup. A tuneup includes many things so you should either replace or check at least the following:
oil change with new filter
air filter
fuel filter
spark plugs
plug wires
distributor cap/rotor
ignition coil
and i'm sure theres more but i'm going blank for a few. anyways this is a decent list to get you started with your new 305. Also might as well check what codes your car is throwing and use these boards as a reference to help solve the problem with any possible codes.
once youv'e got your car running properly, theres numerous things you can do to get more power. tehres always that never ending debate about swapping in a 350 because its cheaper in the long run but i'll leave that for others to tell you about. anyways IMO best place to start is exhaust, a good set of headers and catback will definitely improve your performance as well as sound of the car. Also subframe connectors come highly recommended by members on this board due to the unibody design of our thirdgens. the SFC's come relatively cheap and greatly strengthen the chassis of our cars.
also don't forget about the free mods like porting all your tpi equipment including plenum, runners, and base. although this won't gain you much since there isnt too much meat on these parts to work with, it'll at least grab you a few more until you decide to do something else with teh induction system in terms of replacing it with a better flowing one.
all in all theres tons of things that be done ranging from the simplest of things such as porting your tpi to nitrous or even head/cam swap etc. Provide a little more information including what you have, how much you want to spend realistically, and what kind of power you're looking at achieving.
Old Apr 11, 2004 | 09:23 PM
FastBack's Avatar
Car: 91' Firebird Formula WS6
Transmission: TH700R4
check out the tech section. there is a good article on the suggusted mods for our 3rd gens. its a good article and covers everything pretty much. o yeah, check the egr vavle, that one helped me out.
Old Apr 12, 2004 | 01:00 AM
Yield's Avatar
Car: 91 Camaro Z28
Engine: 5.0 305 TPI
it has 93 thousand miles and i really dont have many worries about the money i wanna spend on it because i dont have bills or anything so i plan on putin what ever i can afford into my car. but ive already done the majority of the things you listed save for the spark plugs and wires...which i was planing on doing as soon as i get the time. many thanks for the info yah gave me though, it was quite helpful...i think once i get started ill be well on my way to havin the braggin rights of havin a baddass car...lucky for me i gotta car that didnt need any real work at all...because the body is almost perfect and so is the interior.
Old Apr 12, 2004 | 01:04 AM
Yield's Avatar
Car: 91 Camaro Z28
Engine: 5.0 305 TPI
oh yeah i almost forgot...as far as my setup goes its totally stock
Old Apr 12, 2004 | 02:25 AM
nikh23's Avatar
if money and time really aren't a problem my personal opinion would be to definitely go with a 350. But like I said thats MY opinion, if you are sure that you want to stick with the 305 then thats your opinion. Also as mentioned run some searches, you'll find a ton of useful information concerning this topic as well as some more information on the 305 vs 350 swap debate.
Old Apr 12, 2004 | 02:29 AM
jfreeman74's Avatar
Car: 1985 Iroc-Z
Engine: 1 BA 305 TPI
Transmission: Probuilt 700R4 - 2800 Stall Midwest
See my sig at the bottom to see what mods I have done to my 305.
Old Apr 12, 2004 | 07:44 AM
FastBack's Avatar
if money isn't a problem why not go with a 355 or a 383?? just a suggustion.
Jake_92RS
Jan 28, 2020 10:37 PM
86IROC112
Aug 17, 2015 02:00 PM
1989formula5.7l
Aug 15, 2015 11:35 AM
st.evel07
Aug 13, 2015 06:15 PM
1nastygta
Aug 8, 2015 07:38 PM
