Tune-up on L98?
Old Apr 21, 2004 | 09:23 AM
gmendoza's Avatar
Tune-up on L98?
I am about to do a tune up on my L98. I'm new to the L98 so I'm not sure what's involved in major tune up for these motors.
So far on my list I have:
cap & rotor
wires
plugs
air and fuel filter
oil and oil filter
I'm I missing anything? What about O2 sensors or ign coil? If so, what kind?
Old Apr 21, 2004 | 12:09 PM
TurboSteve's Avatar
Car: 1987 Formula
Engine: 383
Everything looks good. Depending on your vehicle, there is probably only one O2 sensor. It's probably a good idea to change that if your car has high mileage. Mine went at about 160,000 though. A coil isn't necessary but can't hurt. TPIS says there is a few horsepower in using their Bosch sparg plugs. I've always used AC Delcos myself, but the Bosch one may be something to look into, especially if your looking to buy a good set of spark plug wires as well.
Old Apr 21, 2004 | 03:41 PM
D Stroy H8's Avatar
Car: 1990 Iroc-Z
Don't waste your money on special spark plugs. TPiS gets results in several different ways and their data is skewed sometimes.
AC Delco stock spark plugs are perfect for a naturally aspirated vehicle. (no nos, turbo, or blower)
Try to get your current coil tested. If it's good you save a couple bucks, if it's bad you replace it obviously.
I just recently used Redline Si2 fuel system cleaner, 4 treatments/4 tanks of fuel. I would reccomend it, with the tune up. It scavanged me some 1.5mpg gas mileage and I didn't alter my driving habits catch my drift?
Also clean out your throttle body with throttle body cleaner (don't use carb cleaner) and get a lube job done and an alignment check if you so desire.
91chevyz28
Feb 10, 2022 07:58 PM
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
FormulasOnly
Jul 23, 2018 08:47 AM
Tarizza
Sep 24, 2015 12:57 PM
italiano67
Sep 22, 2015 08:42 AM
