best LTR setup for 305
Old Apr 24, 2004 | 04:09 PM
Jetmeck's Avatar
Car: '89 GTA 9,000 MILES
Axle/Gears: 3.27 9 bolt
cams, heads, intake ? '87 Tpi 305
Old Apr 27, 2004 | 03:22 PM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Transmission: Pro Built 700R4
Add a set of headers to the list.
What are you wanting from the car? My mind reading abilities don't work after 9pm
Old Apr 27, 2004 | 10:07 PM
David 91RS/Z28's Avatar
Don't waste your money with larger runners or base. The stock TPI will supply enough air a 305 will ever need. I do recommend porting the stock base and plenum and gasket matching everything.
Old Apr 27, 2004 | 10:57 PM
Jetmeck's Avatar
That's what I was curious about....Do you think the stock ported base and plenum would support a set of S/R Torquer heads and a decent cam ? Already done the bolt on thing with pulleys, hotter coil and wires, cold air intake, AFPR, 1 & 5/8 HEADERS INTO GUTTED CAT WITH 3 INCH CATBACK w/ flowmaster muffler.
Tranny has a shift kit, raised line pressure, corvette servo with TCI stall.....rearend has 3.73 gears with TA Performance rearend girdle and rear disk conversion. Some minor suspension improvements like lower control arms and poly tranny mount and air bags in coil springs.
Engine has 38k on the clock and wish to optimize the 305 with a cam , heads was curious about the intake side (intake,plenum, runners, throttle body ) and whether they would flow enough with the other improvements ??????
Old Apr 28, 2004 | 11:21 AM
I ran the stock intake matched and ported with a set of stock AL vette heads, a 210/220 .480"/.480" Comp camshaft, Tri-y headers, exhaust, etc 5speed and I got a best of 13.6 at 101mph. Also, stock eliminator cars run a stock TPI with their 305's and they run high 11's.
Old Apr 28, 2004 | 11:52 AM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
David,
What gears were you running with that 305?
If you port out the stock base, the runners will be the restriction. I swapped my runners out and got a good gain from doing so.
Old Apr 28, 2004 | 11:10 PM
3.73's.
Old May 1, 2004 | 01:46 PM
IrocAn87's Avatar
Car: 1987 IROC
Engine: 5.0L 305 v8
Transmission: 5spd t-55
Hey off what vette did you get those heads? Where they off of a l98 vette. They worked fine? No compression problems? They will bolt on fine? 350 heads fit on a 305 motor? I went to your website but I couldn't find anything about your switch to the other heads and cam?
Old May 1, 2004 | 02:43 PM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
You want the 113 casting L98 heads. They have 58cc chambers. They will keep a good compression and work fine with a 305.
Old May 1, 2004 | 02:50 PM
IrocAn87's Avatar
Car: 1987 IROC
Engine: 5.0L 305 v8
How much did those cost you? And where would you get a set of those heads? Off ebay or something?
lt500r55
Sep 1, 2021 01:30 PM
Street Lethal
Apr 30, 2019 12:14 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
stalkier
Dec 6, 2015 11:25 PM
beastin91rs
Oct 9, 2015 07:38 AM
