383 Tpi
Old Apr 25, 2004 | 11:01 PM
hotrodcain's Avatar
Car: 29 roadster
Engine: 383 stroker
Transmission: th350
383 Tpi
I am putting together a 383 stroker 9.75: 1 compresion. What I need to know is what # injectors should I run. Also the cam is 270 duration, 470 lift. The tpi is an 87 iroc 305 tpi. HELP!!!!!! I'm new at this. Thanks
Old Apr 26, 2004 | 01:58 AM
jfreeman74's Avatar
Car: 1985 Iroc-Z
Engine: 1 BA 305 TPI
Transmission: Probuilt 700R4 - 2800 Stall Midwest
I am thinking about doing the same thing and I will probably use something in the 32-36 range.
Old Apr 26, 2004 | 10:14 AM
Chris89GTA's Avatar
Car: 1989 Trans Am
Engine: 355 HSR
Transmission: Pro-Built 700r4 w/ 3400 converter
Axle/Gears: 10 bolt w/ 3.42 gears
B/c of the air restriction of the TPI intake, I would say you definatley wouldn't need more than 30 lb injectors. A buddy w/ miniramed, fully ported AFR 383 230/236 setup, is running 30s and not maxing them out. And that is with a lot more airflow than a TPI is going to be able to deal with.
toronto formula
Nov 10, 2015 06:17 AM
bdads
Aug 24, 2015 06:01 PM
86White_T/A305
Aug 17, 2015 12:16 AM
85Iroc-Z
Aug 13, 2015 01:58 AM
Sanjay
Aug 12, 2015 03:41 PM
