zz409 Cam and 350 engine
Old Apr 26, 2004 | 02:59 AM
lokoRS's Avatar
Car: 89RS
Nice website u guys have here!!
I've got a super ram which i plan on getting extrude honed, and a pair of AFR 195 heads milled down to 58cc because its going on a zz-shortblock.
Ive done some seaches, and most of the people ive seen with the super ram go with the lpe 219 cam, but i want a lil' bit more so i was considering zz409 cam. Its got a single pattern, which the superram likes and has a little more duration, but i havent heard anyone with a 350 with this cam. Anybody with it, can i get some feedback from you? How are the street manners? I still want to be able to pretty much smoke anyone stoplight to stoplight, so i dont want to lose too much lowend torque.
Old Apr 26, 2004 | 04:36 PM
lokoRS's Avatar
Car: 89RS
Nobody has this setup or any suggestions?
Old Apr 26, 2004 | 04:53 PM
OMINOUS_87's Avatar
You might want to expand your search to other cams as well.
The CC XR276HR is also making alot of power in several Superram cars and is now a very popular choice as well.
Old Apr 26, 2004 | 04:59 PM
lokoRS's Avatar
Car: 89RS
Yeah i was looking at that cam too. Its an LT1 cam , so will i need to do any modifications beside shave down the dowell pin?
Wut about the Comp cams XE 282 HR cam? I forgot who mentioned it but that seems like its a pretty healthy cam. Too big??
Old Apr 26, 2004 | 05:46 PM
lokoRS's Avatar
Car: 89RS
Also, ive read that the 276 HR has 112* lobe seperation, but on CC's website, it says it has 114* lsa. which ones correct?
Old Apr 27, 2004 | 11:46 AM
chikn305's Avatar
I have a friend that is running a zz409 with the superram in an 86 vette. The first trip to the track it ran 7.62@ 88.78mph with a a 1.57 60ft. The rest of the combo is out of the box afr 190 hooker long tubes comp cams1.6rr and b&m 3000 holeshot non lock up converter 30lb accel injectors. He was running a miniram and switch to the super ram and just changing the intake same timing fuel pressure same shift points he picked up alittle over a tenth and alittle over 1mph
Old Apr 27, 2004 | 01:58 PM
Ragtop89's Avatar
I'm running that cam on my 355 SuperRam engine.
My first (and last) trip to the track with it netted me a 13.7@102 on a stock APYP tune.
3 weeks later my fuel pump DIED.
I had been experiencing some fluctuations in performance for about 3 months before the pump went out.
I have no idea what my car runs now with a good pump.
It sounds nasty though!
Frozer!!!
Jan 19, 2024 04:55 PM
Jake_92RS
Jan 28, 2020 10:37 PM
camaro71633
Sep 1, 2015 10:24 AM
NinjaNife
Aug 23, 2015 11:49 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
