fuel pump sending unit?
Car: 88 Trans Am
Engine: lt1 intaked 355 makin 277 on 25 psi of fuel pressure and stock timing :)
Transmission: A4 stock... that moved a mobile dyno a foot shifting into 2nd :)
does the fuel pump sending unit have an "anti bleed back valve"? the problem i am having is that when i turn the key on it will bump up to 40 psi then drop to 0 in less than 2-3 sec's but when i get it started it runs at the normal pressure? what is up with that please help out guys just bought this 88 t/a and just trying to work the bugs out
Car: 1989 Iroc-Z
Engine: 5.7L TPI
It has what is called a Pressure Control/Rollover Valve in it. See item #10 in the attached picture. You could also have a bad fuel pressure regulator or leaking injectors. If you have a Holley Adjustable Fuel Pressure Regulator, this is a normal occurrance. To check for a bad fuel pressure regulator, pinch off the fuel return line (5/16") at the flex hose and turn the key to prime the system. If the pressure holds steady, the regulator is bad. If it doesn't hold, you either have leaking injectors or a bad pressure control/rollover valve on the sending unit.
Car: 88 Trans Am
DUDE U ARE THE ****
will check tomarrow
thanks also i was driving today and hit the gas to pass a car and then the RPM's wound up and got high the check engine light came on and started flashing and the car started to buck... but i have no codes ?
will check tomarrow
thanks also i was driving today and hit the gas to pass a car and then the RPM's wound up and got high the check engine light came on and started flashing and the car started to buck... but i have no codes ? Senior Member
Car: 88GTAnotchbac/91 -Z/66 Chevelle
Engine: All strokers
Transmission: Pro built 700r4's
fuel pump
Could be the onset of a fuel pump that is worn out...
When they start going bad they usually start by being incapable of maintaining constant pressure.
Ghettobird52
Jul 5, 2024 11:18 PM
92camaroJoe
Aug 13, 2015 06:07 AM
