$270 bj
Old May 9, 2004 | 09:53 AM
T/A_TERROR's Avatar
Car: 85' T/A
Engine: sbc w/tpi
$270 bj
what the hell.
ok, so I installed a set of siamese runners on my car last friday. no vacume leaks, no issues. took my car to the track later that day and low and behold.......14.9@92mph.
pretty amazing when compared to a 14.6@94mph on the oem runners.
everything was installed perfect, any ideas what the hell happened........I'm really hurtin' here
Old May 9, 2004 | 11:13 AM
CaptPicardsZ28's Avatar
Car: NCC-1701-D (docked in AZ)
Engine: impulse drive
Transmission: fusion reactors
Axle/Gears: Rescued from the Borg by my crew
Re: $270 bj
Originally posted by T/A_TERROR
what the hell.
You will never get good numbers choking out that 400sbc with tpi. Even a heavily modded one wont do much for you. I switched to HSR because of it. Cant explain the higher qtr time though. Sometimes things dont always work the way aftermarket products claim they will. You certainly should have shaved a little more time off tho. How was your launch etc. It could be the driving (not a knock on you). The slightest difference can lead to different times. Did the tires hook? etc.etc.....
Old May 9, 2004 | 11:27 AM
T/A_TERROR's Avatar
Car: 85' T/A
Engine: sbc w/tpi
60' was the same. the shortage was defanetly in the top end. however I'm going to take it apart and port the upper manifold and see if that makes a difference.
still reseaching swiching to an LT1 manifold
Old May 9, 2004 | 01:37 PM
Insomniac92z28's Avatar
Car: 92Z28
Transmission: A4
Upper plenum porting will help, but not much. The biggest restriction is in the base, right before the air enters the head. You can widen that area a lot and pick up some power. It will never run out like a short runner manifold would though.
Botch
Old May 9, 2004 | 02:02 PM
kevinc's Avatar
Car: 1982 Z28
Re: $270 bj
what the hell.
If you're running high 14's with a 400ci engine, something is wrong. My 355 with stock-runner TPI ran 13.2 at 102, stock runners. I can see where the airflow restriction is limiting the 400's power production, but it can't possibly choke it down to make less power than a smaller engine...
Old May 9, 2004 | 03:04 PM
I would do a search to find out which manifold is best for you. There are several comparisons available. Each manifold is set to handle only so many cfms. If it handles 270 cfms then that is what you get unless you port and polish. From what i understand runners need to be ported in at least 2 inches. In effect what you are doing is shortening the length of the runner by doing that. However, I would think that even with a 400 and tpi you ought to be doing better than 14.9. What are you running for a cam? The cam makes a difference on high end as well.
Old May 9, 2004 | 03:07 PM
MdFormula350's Avatar
he runs good on the street though kept up with me but i was spinning.
Old May 10, 2004 | 06:53 PM
Car: 92Z28
Transmission: A4
If he has a 400 and is having trouble keeping up with your stock l98 it is sick!
Charlie
Old May 11, 2004 | 11:50 AM
FocusGhia's Avatar
Car: 88 Camaro IROC T-Top - Gunmetal Grey
Engine: 305 TPI V8
What about different weather conditions?
your 60 foot time might be the same but if the air density was lower your motor wouldn't be making as much power so the rest of the run could suffer?
Thing is to lose that much would need quite a difference in power...
Just wondered if it might be a contributing factor?
Old Mar 27, 2005 | 12:12 AM
1meanGTA's Avatar
Car: 1987 GTA/1998 Explorer
Engine: 355, trick flow heads, zz409 cam, 3
Transmission: 700r4, shift kit, valve body
Axle/Gears: precision 3.73's, auburn diff
where are you guys from in maryland? i live in west virginia, about 15 minutes from hagerstown.
NillaHead
Dec 18, 2001 11:23 AM
Allan
Dec 14, 2001 03:15 PM
gruveb
Carburetors
Dec 14, 2001 12:43 PM
FatOne
Dec 8, 2001 08:25 PM
GOLD85
Nov 4, 2000 11:56 AM
