eliminate 9th injector
Old May 13, 2004 | 01:12 PM
IROCthis88's Avatar
Car: 1988 iroc-z all stock for now
Engine: LB9 305
Transmission: 700R4 3.42 posi rear
i wanted to know id there is a way to eliminate the 9th injector without going thru vortec, i am running a LB9 and am lookin to make it perform a bit but the 1st thing is to eliminate this 9th injector.
Old May 13, 2004 | 02:02 PM
ThirdGenFire's Avatar
Car: 2000 Trans Am and a 85 Iroc-Z
Engine: The Mighty LS1& 305 just beat meTPI
Transmission: 4L60E and 700R4
I belive you have to get your Prom burned for that. A custom prom is in order.
What do you wanna do to your car?
Old May 13, 2004 | 03:36 PM
IROCthis88's Avatar
Engine: LB9 305
im planning on running a comp cams 218-224* 500-510 " lift cam, k&ns air foil and im gonna look into a 22-2400 stall convertor. the car is stock with the 3.42 posi rear and about 110k miles on it, nothin too major just enuff to mess with the 5.0 guys and destroy some ricers
Old May 13, 2004 | 03:54 PM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
Why would these mods require the removal of the 9th injector?
Old May 13, 2004 | 03:59 PM
Kinda what I was getting at.
Those look like some mighty nice mods you are planning. The cam seems a bit to high though.
Old May 13, 2004 | 04:14 PM
IROCthis88's Avatar
Engine: LB9 305
well, im lookin to open up the 305 a bit, and i figured that if im gonna have the motor apart for a bit ill remove the extra injector, i wasonly lookin at it because if the 89-92s didnt have it there might be a restriction with it but im only tryin this instead of switchin over to the 89-92 set up
Old May 13, 2004 | 09:02 PM
Ricktpi's Avatar
The 9th injector is only there to squirt a little extra fuel in during cold starts. In 89 it was eliminated & the ECM was reprogrammed to provide the extra fuel via the standard 8 injectors. There is no performance advantage in removing it since it is not a restriction, it was only done to simplfy things since they often went bad.
Old May 14, 2004 | 07:18 AM
S10Wildside's Avatar
Street and Performance makes two pieces to block it off. One plug for the rails ($15) and one plug for the injector ($5).
http://www.hotrodlane.cc
Old May 15, 2004 | 01:30 PM
IROCthis88's Avatar
Engine: LB9 305
thanks s10 a friend of mine was tellin me about that but he couldnt think of the name of the place who had it. :rockon:
92-Formula
Dec 12, 2015 10:34 PM
BLK87Z
Sep 18, 2015 11:29 PM
ronchic
Mid-Atlantic Region
Sep 15, 2015 08:04 PM
BAMiller
Sep 14, 2015 06:38 PM
webeeZ28
Sep 14, 2015 12:00 PM
