Valve seals or something else???
Old May 13, 2004 | 07:48 PM
arejay86's Avatar
Car: 1988 IROC-Z
Engine: 305 TPI 30 over
i've been told by several people that when i start my car, i get a puff of blue smoke, but only when i start it. a lil history, i have an 88 IROC-Z with a 305 TPI. I've heard that this is just because of the valve seals have become hard and that this doesn't affect the motor, is this true or do i have to be concerned about something larger?
RJ
Old May 13, 2004 | 09:15 PM
Its the ROC's Avatar
Car: then:1986 Z/28 now: 95 Trans Am
Transmission: TH-700R
i have this same problem. so im replacing my valve stem seals
Old May 13, 2004 | 11:16 PM
LAFireboyd's Avatar
Axle/Gears: 9-bolt/3.45
I'm sure I sound like a broken record, lol, but switch to Valvoline MaxLife oil.
Yes, your problem is most likely the valve seals. It's a fairly normal condition as our engines age. MaxLife helps to recondition the seals and lessen the leaking--even elimintate it if it isn't very severe. It works!
IMO, MaxLife is the best oil for our OLD engines. And for those who use synthetic and don't want to switch back to dyno, you can get MaxLife in synthetic too--but only lighter weights(5W-30 & 10W-30).
Old May 13, 2004 | 11:42 PM
onebinky's Avatar
yep, about 99% of the time it's worn out valve seals. They allow oil to seep down through the valve guide into the intake runner, so when you start it you get the "plume of doom"
Really won't hurt anything, but it adds alot of class to your ride when you don't smoke out the neighborhood upon startup
You can get the entire valve seal kit from GM for about $35. I think felpro also makes a kit for about $20. I went with the GM kit for those.
Bubbajones_ya
Jul 6, 2024 08:32 PM
355tpipickup
Sep 13, 2015 11:35 PM
bamaboy0323
Sep 12, 2015 07:14 PM
1Aauto
Sponsored Vendors
Sep 10, 2015 02:02 PM
tgp1990
Sep 4, 2015 06:24 AM
