What's a good price for a set of used 91' LB9 heads??
Old May 12, 2004 | 08:51 PM
grafx's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Transmission: Pro-Built Automatic/Vigilante 2800
I found a set of good used LB9 heads off a 91' with 80k on them, does 125 shipped sound like a good deal??
Old May 12, 2004 | 08:59 PM
ThirdGenFire's Avatar
Car: 2000 Trans Am and a 85 Iroc-Z
Engine: The Mighty LS1& 305 just beat meTPI
Transmission: 4L60E and 700R4
I guess. Are they rebuilt or anything?
grafx's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
no
Old May 13, 2004 | 12:21 AM
smithtc's Avatar
If your willing to go to a junk yard and pull them off yourself, or maybe even pick up some already off, or at least pull them off of an engine out of the car...$25 bucks +/-.
You will have to consider if the extra $100 you pay will offset the time and effort involved in getting the heads locally. How will you know the ones you get are not cracked, or have too much valve seat recession, etc.? Do you have a budget? Extra expenses need to be considered and compared to aftermarket heads...
I have seen Complete, ported, assembled heads ready to install at swap meets for $200+.
I don't think $125 for the LB9 heads needing work is a good deal.
Old May 13, 2004 | 12:30 AM
grafx's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
I didn't think so either plus of the fact that they may in fact be cracked and I wouldn't feel comfortable putting used heads on my engine which means the expense of valve job, and magnafluxing the heads.
What's a good set of aftermarket heads for a 305 TPI that won't break the bank??
Old May 13, 2004 | 02:05 AM
The Wrold Products S/R Torquer Heads area good set of heads that will not break the bank.
Old May 13, 2004 | 12:31 PM
grafx's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
how much
Old May 13, 2004 | 01:20 PM
About $760 for the pair with everything.
Old May 13, 2004 | 09:59 PM
f-crazy's Avatar
Car: Bright Red 91 GTA
Engine: CARBED LT4
Transmission: MK6
FWIW, i told you that the heads are good to go...no cracks or in need of a valve job..you can tell both these things by looking at the exhaust valves...i wouldnt sell them as "good to go" if they werent...id bolt them back on my motor if it wasnt reversed cooled =).....
And just an FYI, those world products 305 heads are junk out of the box..like 20-25 cfm off the vortecs....
081's and 416's can be HOME ported to flow more then the vortecs....
Old May 14, 2004 | 07:39 AM
grafx's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
just saying that I don't feel comfortable bolting on a set of used heads with out knowing for sure that they are good to go by having them magnafluxed, and for total comfort....a valve job. I'm just trying to find out if going with a set of aftermarket heads out weighs the cost of used with machine costs. But I figured that a cheap set of aftermarket heads would cost around that much.I would really rather go with a set of stock heads though.
I'll try and let you know by the end of the week if I want your heads or not. Sorry if it sounded like I was calling you a lier.
Old May 14, 2004 | 11:32 AM
f-crazy's Avatar
Engine: CARBED LT4
Transmission: MK6
Never took it like that, and its totally understandable,...i wouldnt buy a pair without knowing either...I wouldnt sell them as good to go with them needing work...i dont need that type of hassle ya know....and id do what ive done when other people bought stuff off me...not cash the money order untill they recieved there parts and are satisfied with them...Hell i havent cashed the M/O from the bellhosung i sold 2 weeks ago becasue the guys hasnt told me if hes satisfied with it yet....i REALLY REALLY do not want any part of that "scam seller" or "this isnt what i bought" crap....
Old May 14, 2004 | 01:13 PM
smithtc's Avatar
www.revolutionaryperformance.com/products.htm
This guy will work with you on whatever you want at good prices.
This is from the link above. For price comparison.
$125 is still too much (IMO) when you have to change springs and hardware. Plus, they will need some porting (bowl blending at a minimum) if they are to be worth anythin at all before installing on the short block (IMO).
DOMESTIC HEADS
SBC OEM heads, matched set, 3 angle valve job, surfaced, new 1.94/1.5 valves, HD springs, retainers, locks and positive seals $400
SBC OEM late model, centerbolt heads, matched set, 3 angle valve job, surfaced, new 1.94/1.5 valves, HD springs, retainers, locks and positive seals $450
SBC OEM heads, matched set, 3 angle valve job, surfaced, new 2.02/1.6 stainless Manley valves, HD springs, retainers, locks and positive seals $500
SBC Pro Topline 180, 200, 220 or 235cc runner Iron heads with stainless valves, hydraulic or solid flat tappet .550 or.600 lift springs, 3/8 or 7/16 studs and guideplates, retainers and locks $825
SBC Pro Topline 180, 200, 220 or 235cc runner Iron heads with stainless valves, hydraulic or solid .660 lift ROLLER springs, 7/16 studs and guideplates, retainers and locks $875
colton_carlson
Mar 8, 2019 12:21 PM
Reddeath210
Oct 6, 2015 08:20 AM
camaro71633
Sep 1, 2015 10:24 AM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
