What voltage on the TPS?
Car: 1987 Trans Am
The vehicle is a friend's 91 Z28 TPI 5.7. Also, which wires are probed to get the readings? I have done this on other cars, but never on a TPI. Thanks!
Car: 1989 Iroc-Z
Engine: 5.7L TPI
You would probe pin "A" (negative, wire should be black) & "B" (positive, wire should be blue). Voltage with throttle closed and ignition "ON" or at idle should read less than .96 volts. The TPS on this engine is not adjustable, it is determined by the ECM.
Car: 1987 Trans Am
So what do you do if the voltage reading is off? The car hasn't been right at low engine speeds since the TB was installed (I haven't seen or driven it yet, just going on what the guy said). Its a Holley TB if that matters. The mechanic who installed it said he couldn't get the proper adjustment (not slotted like some of the older ones), and the owner tried to get a replacement TPS that did, or at least has some material that could be removed to make it adjustable. He got one from the dealer, and while it isn't adjustable it appears to have enough material to make it adjustable. I remember having to do this on another vehicle (can't remember what it was, possibly a Buick GN or a 5.0 Mustang), and assumed the Z28 was the same.
Car: 1989 Iroc-Z
Engine: 5.7L TPI
What size throttle body is it, 52MM or 58MM? The standard stock TPS for a 1991 stock 5.7L TPI engine is not adjustable, if there is a problem with the TPS. The only recourse is to replace it. The two wires to back probe are pin "A" & ""B". Pin "A" (ground) is the top wire on the TPS connector and pin "B" (positive) is the center wire. I don't know if the size of the throttle body might have an effect on it or not. It might need a TPS designed for that throttle body. BTW, what are your voltage readings?
Car: 1987 Trans Am
Its a 52mm. I haven't looked at the car yet (the owner is bringing it over Tuesday night), so I'm not sure where the voltage is or if her even checked it. Apparently there was no problem before the new throttle body was installed, so I figured it was the TPS voltage.
Car: 1972 LT1 Corvette
Engine: 350 HO
Transmission: M22 Heavy Duty 4 Spd
Axle/Gears: 336
Go to this link, maybe it will help. IAC and TPS Adjustment
Car: '89 GMC Pickup
Engine: 383 SBC Stealth Ram
Transmission: 700R4/VIG 3200
Also, I didn't know a '91 TPI TPS wasn't adjustable. Guess I never needed to move one of them. But, a TPS from an older model should be adjustable and work just fine. It may even be required to get it set properly.
Sounds like you know enough about it to figure all that out though.
HTH
Car: 1989 Iroc-Z
Engine: 5.7L TPI
BumpaD82
Feb 26, 2016 02:57 PM
HoosierinWA
Oct 7, 2015 10:15 AM
MikkoV
Sep 9, 2015 04:25 PM
