SVO Injectors, pressure, and eprom
Car: Sexy
Engine: Stock
Transmission: Slipping
I've done the searching. I know that 24# SVO's are actually 25.8# at GM pressures.
My question is: Do you think it'd be better to run the injectors at the pressure they were designed for? Would the extra pressure cause any type of premature failure? I can tune the eprom either way, I'm just asking opinions.
Car: 92Z28
Transmission: A4
The SVOs will work fine at 43-75 psi. I have ran them on a blown FMU setup at up to 75 psi without failure. If you can tune it in the chip (constant) do so and you won't have any trouble.
Charlie
Charlie
Justin92GTA
Aug 27, 2015 11:16 PM
