cant get the tpi to idle
Subscribe
May 17, 2004 | 08:25 PM
Help!! I've just put together a 5.7 with a crane cam 280H series, actually a blue racer cam wg-1159, and I can't get the car to start or even to fire! I've checked the timing chain, timing marks, distributor, valve adjustments, everything that I can think of, can anyone help? I just changed from the XE294H cam as I thought that was the problem, too much cam, but I'm having the same problem with the smaller cam..
specs are adv dur 280/290 .050 dur 214 224 vlv lift 443 465.. so not a really big cam, but I'm having lots of problems getting to to run.
thanks
dale
Reply 0
May 17, 2004 | 11:05 PM
Your title block says "Can't get TPI to Idle" then you say you can't get it to fire. Which is right? Very meaningful to the help you may get.
Reply 0
May 23, 2004 | 07:55 AM
Is the Distibuter in 180 degrees off?
Reply 0
May 23, 2004 | 09:53 AM
that or the base timing is way off. crossed wires?
Reply 0
Subscribe
