383 hot cam
Old May 26, 2004 | 01:49 AM
89irocadam's Avatar
Car: 89 GTA 14 Tundra Crewmax
Engine: 388hsr 5.7 32valve
Transmission: T56 6spd auto
383 hot cam
Hi I am new to the board i was wondering what would i have to use i nthe way of valve spings on LB9 heads with the hot cam and would i have to have the heads machine for clearence on for the springs (using 1.5 rockers)
thanks
adam
89 Iroc (working process of a 383)
Old May 26, 2004 | 10:27 AM
Insomniac92z28's Avatar
Car: 92Z28
Transmission: A4
Scoggin dickey sells a spring, lock and retainer set that will fit the stock spring pocket and is good up to .600 lift for $93. They install at 1.800" though so you will need to make sure you have the room for them. The valve guide clearance will need to be checked for running the hotcam, as it may be close to smacking the retainer against it. I would suggest putting screw in studs in also. Because of manufacturing tolerances the heads vary a little, so I would check both sides, and not take any action untill you have checked your own heads before deciding what to do.
Charlie
Old May 26, 2004 | 10:31 AM
cali92RS's Avatar
Car: White KSwisses
Engine: 5.3L Gen III
Have u already bought that hotcam, and is it a stock TPI?
If not, i would go bigger than that hotcam in a 383, but thats my opinion.
Old May 26, 2004 | 02:55 PM
89irocadam's Avatar
I would go bigger with it but i simply dont have the cash right now plus i want a little bit of fuel economy as well. i will also have to buy a trans before long after this engine is in becasue i have a t-5 i imagine from whati read i should be ok with clearences but i dont know till i can accully measure the hieght and all thanks for the reply guys
adam
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
gixxer92
Sep 1, 2015 04:32 PM
lt1z350
Aug 28, 2015 05:57 AM
bdads
Aug 24, 2015 06:01 PM
LT1Formula
Aug 20, 2015 09:36 PM
