1/4 mile times?
Old Jun 3, 2004 | 06:46 PM
btcamaro's Avatar
Car: 91 Camaro
Engine: 383
1/4 mile times?
I know this gets asked alot but what kind of times should I expect to get out of my car It just doesn't seem like it is running as good as it should. My combo is in my sig.
Old Jun 3, 2004 | 08:10 PM
clippjr8's Avatar
At the very least you should be running in the mid to low 13's. I had a similar setup with the same heads and cam and ran 13.5 all day long. what are you running in the 1\4?
Old Jun 3, 2004 | 10:16 PM
btcamaro's Avatar
Car: 91 Camaro
Engine: 383
I have not run it since the miniram but before that i had the edelbrock intake/runners and the best that i could run was a 14.4.
Old Jun 4, 2004 | 04:25 AM
porkyzilla's Avatar
Car: 89 iroc-z 5.7tpi 350,
Engine: 5.7tpi 350,
thats funny im all stock and with a leak at the intake base manifold, and throttle body intake leak....i ran a 14.2 same nihgt 15.2 and 14.7 consistent figured out why the intake leaks haha almost back together ill bet ill break into 13's all stock
Old Jun 4, 2004 | 08:31 AM
speed88's Avatar
Car: 1988 Trans Am GTA
Engine: 383
You only ran a 14.4 with the mods in your sig minus the Miniram plus the Edelbrock stuff?? WOW!!! I ran consistent 14.3's with my old L98 that had Edelbrock shorty headers, 2.5" flowmaster exhaust, typical free mods, and ported L98 heads. Basically a stock L98 with exhaust and fresh cylinder heads. (No major intake or exhaust port work was done on the heads, just 3 angle valve job, bowl seat porting, and new valve stems). I think there is more wrong with your motor than you think.
Old Jun 4, 2004 | 09:09 AM
smithtc's Avatar
355, vette heads, mini ram, zz9 cam, 24lb inj. slp 1 3/4 headers, 3:23 gears, 5spd trans, 9.5:1 comp 7730 ecm
If nothing mechanical is wrong...
My $0.02
Are the stock heads unported? If so, then your heads are a restriction. They're not bad, but not ideal for your combo.
24 lb inj. should work fine, but do you have a chip burned?...or a tune worked out in conjunction with your 730 ECM? Major modifications such as yours require changes in the chip.
I think the 3.23 gears need to be swapped for a higher numerical ratio set. 5-speed trans...How well do you shift?
9.5:1 compression seems low for the aluminum heads...and May be too low for that camshaft.
I'd call TPIS, since you are using their intake and cam., and get their opinion on your combo, and see what they recommend. I'd like to hear what they have to say.
Old Jun 6, 2004 | 10:16 AM
btcamaro's Avatar
Car: 91 Camaro
Engine: 383
I don't think anything mechanical is wrong. I checked the compression and it was 150lbs on every cylinder is that good or could that be a problem? I am burning my own proms but all I have worked on is the ve tables I haven't touched the wot tables yet because I am waiting on the money for a wbo2 sensor.
Old Jun 6, 2004 | 10:34 AM
robsgta's Avatar
Car: 88GTAnotchbac/91 -Z/66 Chevelle
Engine: All strokers
Transmission: Pro built 700r4's
1/4 times
Your car should be a strong mid to low 13 second car. BUT the major difference in your time should depend on getting some slicks since your car already is standard . (traction will make you or break you) if your trying to run fast with street tires your wasting your time.
BTcamaro what is your 1/4 mile and 60 foot time right now??
Old Jun 6, 2004 | 10:47 AM
btcamaro's Avatar
Car: 91 Camaro
Engine: 383
I have not ran it since the miniram but my best with the edelbrock setup was
60' 2.04
1/4 14.43
It doesn't seem to run any better I just haven't had a chance to run it yet.
Old Jun 6, 2004 | 11:45 AM
kevinz85's Avatar
Car: 1987 GTA
Transmission: A4
How fast are going though the traps?
Old Jun 6, 2004 | 09:24 PM
btcamaro's Avatar
Car: 91 Camaro
Engine: 383
I can't remember and I can't seem to find my time slip but I think that I was trapping at 91 or 92
Old Jun 6, 2004 | 10:31 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
that seems low for that E/T ...no ?
Old Jun 7, 2004 | 12:14 PM
89305RS's Avatar
Car: 96 s-10, and 89 camaro RS
Engine: 305 TBI with alot of mods
Transmission: 700R4 B&M shift kit
yeah it is low. I ran a 15.2 @90mph friday. But the TBI gods think that it needs a tune for the 14s. I should be mid 14s with a 90 mph trap.
Old Jun 7, 2004 | 04:47 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
I ran 15.1@93 ..... it was only good for a 14.7 I was told ...
90 is optimistic for mid 14's ,but with your setup its now time to learn how to burn proms ...... I need to as well but .... you really need to learn
....did you say you got this from TPIS? . If so did you get their prom ?
Old Jun 7, 2004 | 05:37 PM
robsgta's Avatar
1/4 mile
I dug up a time slip from my stock configuration with just a few simple cheap bolt ons. air foil,k&n,flowmaster muff,custom chip 160 thermo,modified MAF, other than that it was bone stock with BFG slicks I ran a 2.13- 60 foot, 1/8 - 9.089 mph @77.18, 1/4 mile 14.113@96.99
Another thing you might want to try is let some one else drive your car a time or two it might shock you. A standard cars biggest
loss or gain will be the leave off the line.
Old Jun 8, 2004 | 10:31 AM
Captain C's Avatar
Car: 1985 IROC-Z
Engine: 1989 350 4 bolt roller block
Transmission: ProBuilt 700R4 Road Race with Edge 9.5" 2800 stall lockup converter
Don't feel too bad, my best ET so far is a 14.37 @98.43 ( Track is 700' elevation and had a 103* temp that day)
I'm in the process of upgrading to 30# injectors. The car just seems to lay over at half track and I'm wondering if I'm just not sending enough fuel to the engine (not fuel pressure).
I went back over my old time slips and noticed that my actual best ET's were with the timing set at 10* initial advance. I don't think I've made a run with the timing that low since I pocket ported the heads. The car pulls really hard on top end with the timing at 16* but it doesn't have the low end it needs with the current gearing I have. Too much time is spent out of the power band in third gear.
My ET's also suffer due to a lack of traction with street tires. I have to launch at half throttle off the line and then floor it once moving. Also, this was before the newly added Probuilt transmission and Edge 9.5" 2800 RPM stall converter. My previous converter was a generic 12" 2500 rpm stall unit that doesn't work nearly as well. I'm anxious to try this thing out once it's back running. With the better converter I might just be able to take a little more advantage of a higher timing setting too!!!! But first things first, try 10* then go up from there....
Definitely want to do the burn your own chip thing or go with an Excel computer. Just don't have the duckets for either at the moment.....
Old Jun 8, 2004 | 02:55 PM
smithtc's Avatar
So, what did TPIS have to say?
Old Jun 8, 2004 | 10:31 PM
btcamaro's Avatar
Car: 91 Camaro
Engine: 383
I havn't had a chance to call them I have been really busy with work and I also want to check everything that they might ask me to check already done. I will post what they tell me as soon as I get a chance to call them.
Thanks for all of the replys
Old Jun 9, 2004 | 08:11 PM
rottonj's Avatar
1/4 mile times
I used to own a 89 formula 350, mods were flowmaster muffler,b+m shift kit, k+n with homade ram air, air foil and timing bumped to 12 degrees(sunoco 94 ultra) and it ran 14.2 at 97 mph.That was in 1992 and I thought that was pretty quick.
Old Jun 12, 2004 | 03:55 PM
btcamaro's Avatar
Car: 91 Camaro
Engine: 383
well I ran my car last night with the mini-ram and the best that I got was a 14.61 at 95.7mph I was going to work on my chip some but my laptop harddrive crashed on me at the track. My 60' was 2.2 so i need to work on the traction but I was hoping to be running a better mph than this.
Old Jun 12, 2004 | 05:53 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
You definetly need to get a new eprom burned. Going to a Mini Ram is a big time change. Allen
Old Jun 13, 2004 | 12:07 AM
daxfas26's Avatar
Car: cobalt ss/sc, 91 z28, 92 z28
Engine: 385 stroker
Axle/Gears: stock 10 bolt 3.73
Dang man you really must have something wrong??? Are u getting spark and fuel to all cylinders. Sounds like with those nbrs your only running 7 cylinders. I would check each plug if they make spark and the fuel injectors make sure they in good working order. I had a 383 with stock unported tpi and out of box trickflow g2 heads with 9.2 compression ran 13.2 @103.5 mph all day long. One last question how's your car sound does it sound like its got a big cam is it spewing a lot of black smoke?
Old Jun 13, 2004 | 01:35 AM
btcamaro's Avatar
Car: 91 Camaro
Engine: 383
If it was running on just 7 cylinders wouldn't it have a mis? It seems to be running ok just doesn't have the power that it should I will pull all the plugs tommorrow just to see if anything looks wrong but I am not real sure what I am looking for.
Old Jun 13, 2004 | 05:35 AM
daxfas26's Avatar
Engine: 385 stroker
when I had that last setup one of the fuel inj clips came off it make lot of black smoke and sound like it had a really big cam in it glub glub glub, so Id take a screwdriver and test each spark plug wire just stick the screw driver inside one spark plug at a time and put the rod of screwdriver over something metal and see if u see spark in each cylinder. careful this will shock the crap outta you if u are not careful. and i recommend having a friend to start the car everytime u check one. then get a voltmeter and see what all injectors read all should be pretty close to the same if u see one thats way off could be a problem? I guess try this for now and if it still isnt the problem we have eliminated that it could be spark or fuel. it could be internal or your transmission? hell it could be anything lol!
Old Jun 13, 2004 | 08:15 PM
robsgta's Avatar
1/4 mile
Bt I was wondering if you power shift or have ever tried to power shift.
I mean once you leave and floor your throttle out of 1st gear your right foot never leaves off the throttle to shift from first to second or from second to third etc etc with only your left foot punching the clutch to momentarily slam it into gear.
Old Jun 13, 2004 | 11:32 PM
btcamaro's Avatar
Car: 91 Camaro
Engine: 383
I don't power shift the trans because I have nuked one to many trannys if you know what i mean
Old Jun 14, 2004 | 12:54 AM
MaineIrocer's Avatar
Car: 1986 Iroc-Z
Transmission: Automatic
I am kinda new with this racing stuff what i have heard it refured too several times....what do you mean when you say "burn proms "
Old Jun 14, 2004 | 10:55 AM
robsgta's Avatar
proms
Maine Irocer
https://www.thirdgen.org/newdesign/tech/promintro.shtml
Old Jun 14, 2004 | 02:15 PM
87camaroz28310's Avatar
Car: 87 plane jane with gfx
Engine: 350 worked vortec head .515 .515 cam and 1.6 rockers and shorties for now til i can afford the supercomps
Transmission: super t-10 or t-5
Axle/Gears: auburn with 3.42 stock axles
i run 14.52 on my 305 but when i ran slicks it slowed me down so you might do better on street tires. you should be run faster then a 14.4 because i had the times for a 14.2 run and missed 3rd.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
evilstuie
Jan 9, 2020 08:29 PM
Andrew6.688
Dec 13, 2015 10:59 AM
Derick15
Members Camaros
Aug 20, 2015 10:19 AM
