first night at GLDW with my 91 z28
Old Jun 9, 2004 | 08:33 AM
bp91z28's Avatar
Car: 91 z28
Engine: 305 tpi
Transmission: t700r4
hey last night was my first night raing my z28. also first night racing in a domestic and a auto. learning to launch in a auto is real different. well here are my time's on the tree they run a .000 is a perfect launch. neg are red lights
R/T:0.774
60':2.451
1/8:10.263
1/8 MPH:69.41
1/4:15.909
1/4 MPH:88.01
R/T:0.418
60':2.384
1/8:10.128
1/8 MPH:70.02
1/4:15.727
1/4 MPH:88.6
R/T:0.677
60':2.537
1/8:10.324
1/8 MPH:69.63
1/4:15.923
1/4 MPH:90.39
R/T:-.061 RED LIGHT
60':2.563
1/8:10.14
1/8 MPH:72.59
1/4:15.556
1/4 MPH:92.87
R/T:0.413
60':2.334
1/8:9.955
1/8 MPH:72.03
1/4:15.525
1/4 MPH:83.22
R/T:-.389 RED LIGHT
60':2.99
1/8:10.810
1/8 MPH:68.61
1/4:16.599
1/4 MPH:87.02
R/T:.209
60':2.278
1/8:9.944
1/8 MPH:70.37
1/4:15.594
1/4 MPH:84.12
R/T:.049
60':2.457
1/8:10.224
1/8 MPH:67.43
1/4:16.126
1/4 MPH:77.61
Now on the first 5 runs i had my tires at 40 pis( stock is 44) then on the last 3 i tried 35 psi. also the last 3 runs i started having problems with my tranny. at wot the tranny started jumping from 3 to 2nd and back to 3rd. so i called it a night. my suspension is pretty much shot so i know that is on the list of fixes. another problem I had was keeping in one place while torque breaking. thats why i red lighted two of my runs cause the car jumped forward. my mods are on my sig.
Old Jun 9, 2004 | 11:10 AM
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
Transmission: TKO 600
Axle/Gears: 3.54 Dana 44 IRS
what is the elevation of the track you were at? those times are pretty sickly. when my 86 was stock it went a mid to low 15. i am assuming the mods in your sig are for the times you posted above.
Old Jun 9, 2004 | 12:44 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
Depending on your elevation ..... ya that looks bad
here is what I did
1989 5.0L TPI 5 speed 3.08 posi 2.2 60ft ( big *** burnout on street tires....then I read that does nothing for street tires ) 15.1@93 STOCK . with bearing and synchro noise an injector on its way out ....and code 32 MAF isssues ......and 225'000km's ( hard ones I may add ) . Even though the auto's got a different cam you got some mods on there to help compensate that .
...just to give you something else to compare to .
Old Jun 10, 2004 | 07:58 AM
bp91z28's Avatar
Car: 91 z28
Engine: 305 tpi
i think we are at like 600 ft above. i think the heat and humidity was hurting alot of people. it was almost 90* out with 90% humidity. i wasnt the only person have problems. like i said my suspensions is crap. it will be hard to figure if i am having a problem till i fix the suspension. the previous owner cut the springs, and the bushings a falling apart. once i at least replace the shocks, struts ands springs then i will be able to eliminate that. and yes SFC and trailing arms/ pan hard bar is also in the plan.
there was a guy there with a ws-6. before he got his new heads
he said he was running 12's all day. he puts on the new heads i think he said he had stage III's put on. he was running slower. he had morst wheel bounce than i did. the one guy with him was running a 60's SS and was bitching about traction too. so it's hard to say what was enviromental and what wasn't. but for know its all suspension work before i do any more engine work.
Old Jun 10, 2004 | 11:16 AM
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
D's89IROCZ, he already has a crane cam, it says so in his sig anyway. regardless of your traction, the heat and humidity does not make a car that should be in the mid 14s run a 15.5. also your traps are all over the place. you trapped a best of 92mph and a worst of 84mph(still ran a 15.5). somethin is up, that is a big difference in trap speed. does your car need a tuneup or somethin? was the check engine light coming on? with a cam, converter, and exhaust you should be able to run a high 14 at the very least.
Old Jun 10, 2004 | 11:30 AM
bp91z28's Avatar
Car: 91 z28
Engine: 305 tpi
i dont have a cam. i have a crane cam fireball ignition. so you are saying my car stock should be hitting 14's. there is one item that i did not list on my sig. my car had problems passing emissions and when the dealer checked it out they said i have over sized injectors but since i cant prove it yet or even figure out what size injectors i have i didnt place it on my sig. as far as tune up goes plugs, cap rotor all replaced this fall, oil changes current running syntex. now i am getting worried, hmmm. i have no codes. it runs alittle rich. hmmm, i wonder it the cat is clogged? i guess i will have to check. as far as my worst speeds go, my tranny wasnt acting right on the last 3 runs, it was bumping back and forth from 2nd and 3rd at higher rpm. i let it cool down and it acted fine.
my traps are alittle all over because I am just learning to launch in a auto. give me some more practice i should close them in.
Old Jun 10, 2004 | 09:30 PM
WKDCAMARO's Avatar
Car: 1991 Camaro RS
Engine: 350TPI conversion
Those 60 ft times are the worst that I have seen in a long long time. A minivan with a 4cyl can get 2.2's all day long..
I woudl practice your driving techniques, you are on the throttle entirely to hard off the line..
Try and walk it out of the hole until 1/2 way through 1st gear..
Old Jun 11, 2004 | 08:12 AM
bp91z28's Avatar
Car: 91 z28
Engine: 305 tpi
i will try that. i will hopefully get my sfc's by the next time i go.
I am still going to do a 1 over on the motor. the suspension work is going to take awhile.
Hotrodboba400
Dec 10, 2019 07:07 PM
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
Denricci22
Sep 18, 2015 09:02 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
