SD base plate
Old Jun 11, 2004 | 04:16 PM
Parrydise7's Avatar
SD base plate
I finally got my base plate. There is a part that is supposed to bolt to the underside of the base plate. I went to the dealer to order it, but I didn't see it in any of the exploded drawings. I thought it was an oil splash shield, but the parts guy says there is nothing listed in the parts catalog by that name.
Does anybody have a part number for it? Thanks. (BTW, I did do a search).
Old Jun 11, 2004 | 07:54 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Might be called splash shield or windage tray...but why can't you use the original one?
Old Jun 11, 2004 | 08:53 PM
Parrydise7's Avatar
I'm replacing a carb with tpi.
Old Jun 14, 2004 | 04:52 PM
Parrydise7's Avatar
Alrighty, then, for everybody (or anybody) that's interested, the p/n for this part is 14087401. (I think it's the right number. GM describes it as an oil splash shield. I have't gotten the part yet). Anyway, in doing a search for this part, there seem to be several questions:
1. What does it do?
2. Is it necessary?
The two main thoughts seem to be that it either prevents oil from splashing on the lower intake and heating up the incoming air or that it prevents oil from splashing on the lower intake and "coking" on the underside of the intake. (Both seem to be related anyway).
As to whether it is necessary or not, there are two schools of thought: Yes and no.
I called up SD to try and get a part number for the shield. I talked to a pleasant and helpful individual at SD who advised he did not think it was a necessary part (and there seem to be some people on this board that agree).
I'm going to go ahead and put the shield on my vortec base plate because the factory put one on theirs and because Dyno Don, who is going to build the tpi engine for me, says its necessary.
Old Jun 14, 2004 | 05:02 PM
omcrider's Avatar
Car: 1988 GTA
Engine: 5.7L/L98
You got it!!!
Old Jun 14, 2004 | 06:54 PM
OMINOUS_87's Avatar
It also provides a downward angle for oil to flow back down with little restriction.
Its a must have in my book.
Old Jun 14, 2004 | 08:03 PM
Parrydise7's Avatar
Then that settles it!
A short edit to let everyone know that the MSRP is $12.65 (according to gmpartsdirect.com) for this part.
Old Jun 16, 2004 | 01:43 PM
VetNutJim's Avatar
Car: Different One Every Day
Engine: LS1,LS6,L98,L83
Transmission: 700R4, 4060E,Turbo 350, Turbo 400
GM didn't spend 50 cents to put one on there because it wasn't needed.
Every TPI intake I've seen has one. SD sounds like they cheaped out and didn't supply one with their intake.
You're doing the right thing.
Old Jun 16, 2004 | 03:46 PM
OMINOUS_87's Avatar
I am pretty sure none of the aftermarket bases come with the splash shield.
Old Jun 16, 2004 | 09:17 PM
383 rocket bird's Avatar
When I ordered my base plate from SDPC it was included along with the bolts to attach it. -John
Old Jun 16, 2004 | 10:07 PM
OMINOUS_87's Avatar
Mine showed up bare.
Old Jun 17, 2004 | 09:21 AM
omcrider's Avatar
Car: 1988 GTA
Engine: 5.7L/L98
My Edelbrock was also without the shield, I just re-used my stock one.
Old Jun 17, 2004 | 09:25 AM
91wtROH17's's Avatar
Car: 91Z
Engine: 355/afr/sr/lpe219
Transmission: built 700R
My accell came with one bolted up, that was from LPE though.
Old Jun 23, 2004 | 07:13 PM
Parrydise7's Avatar
Sorry to bring this back from the dead, but I just bolted the splash shield on the base plate. The base plate is drilled and tapped to accept the shield. It seems a little odd that SD (or Edelbrock) would make the base plate to accept a splash shield, but not provide one.
Old Jun 23, 2004 | 07:48 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
I reused the one from my stock TPI baseplate and just bolted it on to the Edelbrock TPI baseplate. I believe Edelbrock thinks that mojarity of people take this route so that is why they do not provide one. If they had to provide one the cost would go up and few would use it as they have the old one. Allen
Old Jun 24, 2004 | 09:30 AM
omcrider's Avatar
Car: 1988 GTA
Engine: 5.7L/L98
Precisely, since 95% of people buying these are taking off a stock manifold that has the shield on it, why raise production cost to supply something most people don't need.
Old Jun 24, 2004 | 10:49 AM
Parrydise7's Avatar
There is no apparent consistency. 383 rocket bird (and at least one other) gets one. Others don't.
It isn't a big deal, but there seem to be more than a few people that aren't bothering to install it.
Old Jun 24, 2004 | 11:24 AM
omcrider's Avatar
Car: 1988 GTA
Engine: 5.7L/L98
Technically you don't have to install it, but its not a bad idea and if you have one theres no reason not to put it on.
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
Hotrodboba400
Dec 10, 2019 07:07 PM
Fronzizzle
Feb 9, 2017 09:31 AM
tyeo098
Nov 30, 2015 06:27 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
