smog parts removal...and engine performance
Car: 89 iroc-z 5.7tpi 350,
Engine: 5.7tpi 350,
ok well ive really been learning alot in my auto motive class at college..and i found out that plate on the bottom of the intake manifold with 4 bolts is used to heat up intake charge?? so my question is has anyone attempted to remove it??....
also egr valve i want to get a block off plate...how to i disable the egr valve without hurting engine performance...
Car: 1990 firebird
Engine: 3.1 v6
wouldnt blocking the egr give you horrible gas mileage, or is that when you disconnect it ? , either way i barelly get good mileage so it doesnt matter
