383 guys, what ignition and plug gap??
Old Jun 16, 2004 | 05:44 PM
speed88's Avatar
Car: 1988 Trans Am GTA
Engine: 383
Just like the subject says guys. What ignition and plug gaps are you running? I am trying to decide what mine should be with my MSD ignition, wires and coil. What are you guys doing?
Old Jun 16, 2004 | 06:56 PM
89gta383's Avatar
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Axle/Gears: 12 bolt-3.73
Stock .035
Old Jun 16, 2004 | 10:53 PM
robsgta's Avatar
Car: 88GTAnotchbac/91 -Z/66 Chevelle
Engine: All strokers
Transmission: Pro built 700r4's
ingition & plugs
You should use the plug size that your heads manufacturer recomends. My aluminum heads came with a champion spark plug number that I have been using ever since of coarse they can be cross referenced to what ever brand you prefer.
You can use a larger gap than factory with out any problems considereing that you are using an after market ignition considering your spark is going to be significantly stronger you will have no problems making the jump I would go at least .045 I have seen msd's spark jump over 6 inches ...
Old Jun 16, 2004 | 11:16 PM
OMINOUS_87's Avatar
ACCEL 300+ System, Taylor Wires, NGK Plugs, .050 Gap
Old Jun 18, 2004 | 08:31 AM
speed88's Avatar
Engine: 383
How did you come to the .50 gap. Did you do a test and tune with smaller gaps first and found the .50 to be the best??
Old Jun 18, 2004 | 10:47 AM
OMINOUS_87's Avatar
Lucky guess?
No, after doing the research thats what I setteld on.
You gotta have aftermarket ignition parts though to push a gap that big.
I think MSD has a write up or something floating around about gap also.
Old Jun 18, 2004 | 09:06 PM
CraZ-28's Avatar
Car: 1991 Z-28
Engine: Can you say stroke?!?!
Transmission: 700-r4
Yeah, Jacobs does too. They give you a sheet that basically says if you have this....go to this. Then use that as a starting point for adjustments. Kinda cool.
Old Jun 19, 2004 | 12:35 PM
robsgta's Avatar
ignition
Well Im running a Crane Hi 6 ignition with a MSD Blaster 3 coil,accell 8.8 wires and champion plugs gapped at .045
Old Jun 19, 2004 | 01:57 PM
89Warbird's Avatar
Car: 1989 GTA Nighthawk
Engine: 389 CID TPI
Transmission: TCI 700R4
Axle/Gears: 9 bolt 3.23
I'm running Crane HI-6S with a PS-92 coil. I run Bosch +4's which are factory gapped. when I was runig Champions I gapped them at .045
BRoss99
Aug 10, 2025 05:08 PM
Infested
May 22, 2018 11:56 PM
Street Lethal
Aug 14, 2015 08:25 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
