Do these head suck?
Do these head suck?
376450.....75-81...262/267/305..6 or 7 exhaust bolt holes, 60cc chamber
That is what I found on my motor, that and finally tracked down the block casting number and found out it is indeed a 305. Numbers match the car to boot. But I guess it explains why this 350 (
) was so damn slow
Anyway, back to the heads. I'm putting this engine into a s10 4x4 project, and was wondering if these head with some work, along with a cam and headers would be able to get me to 250-300 hp?
) was so damn slow
Anyway, back to the heads. I'm putting this engine into a s10 4x4 project, and was wondering if these head with some work, along with a cam and headers would be able to get me to 250-300 hp? Supreme Member
Car: '89 Formula 350 & '86 Z28
Engine: L98 & 355ci
Transmission: 700r4 in both
They definatly arent the best, for performance
Here is why, they are made in the late 70s early 80s = light castings
They are also made for small engines = low performance
If you put this in an S-10, youll get stomped by 4.3's everywhere, if its stock
Well that'd totally defeat the purpose of the v8 swap since it has a 4.3 in there already!
What kind of heads and cam should I look for? Most of the recommendations around here involve getting more hp/tq in the upper RPM range. But I'm looking to keep/gain more low end torque since it's going to be a trail rig.
What kind of heads and cam should I look for? Most of the recommendations around here involve getting more hp/tq in the upper RPM range. But I'm looking to keep/gain more low end torque since it's going to be a trail rig. Supreme Member
Engine: L98 & 355ci
The age old question..
"So you want to go fast? How deep are your pockets???"
Start building a 350-400, ditch the 305
Heres my old S-10
Heres my old S-10
But I don't want to go fast.
I just want to go over stuff, usually pretty slowly so as I don't break anything
But for now the 305 is staying, so I'm looking for what can improve it's low-end torque situation.
But for now the 305 is staying, so I'm looking for what can improve it's low-end torque situation. Supreme Member
Car: 86 IROC
Engine: 383
Transmission: TKO 600
Axle/Gears: 3.54 Dana 44 IRS
the aluminum L98 corvette heads would be great for what you want to do. smaller intake ports to keep the velocity up. these heads make excellent midrange power in my 305 and i have a fair amount of cam. i am sure with a milder cam these heads could make a 305 a good strong motor on the bottom end.
355tpipickup
Aug 27, 2015 08:13 AM
