reusing lifters?
Old Jun 23, 2004 | 12:56 PM
IROCZ88x's Avatar
Car: 1988 IROC-Z
Engine: LB9
reusing lifters?
whats the word on reusing lifters with a new cam? (hyd rlr)
my motor has 67k on it and runs well...can i reuse the lifters if there is no sign of obvious damage?...and if i replace em is there a better option out there than the crane ones for 185...?
thanks a lot guys
Old Jun 23, 2004 | 04:37 PM
camaro_60181's Avatar
Car: 1986 Iroc z28
my perssonal opinion is just get new ones.....You have to take them out to get the cam out and back in why not just replace them?
Old Jun 23, 2004 | 04:42 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
Roller lifters? Don't need to replace them unless you are going radical. As you said, no apparent damage, you can throw them back in. They are nothing like flat tappet lifters in that regard.
Old Jun 23, 2004 | 09:05 PM
Car: 1986 Iroc z28
Like I said just my opinion.....That way you know they are good and you won't have to tare dow the motor agian if the reused one go bad...
Old Jun 24, 2004 | 09:32 PM
IROCZ88x's Avatar
Car: 1988 IROC-Z
Engine: LB9
cuz they cost 200 bucks...my thoughts are usually to just buy new if u can afford it cuz it always works out better but im running low on cash after buyin all the other stuff and im trying to cut some costs
Old Jun 25, 2004 | 01:09 AM
rezinn's Avatar
If you know yours work, you can keep them. Might be better to replace if you can see uneven wear patterns on them, though, but they typically don't wear much.
Old Jun 25, 2004 | 05:01 PM
dyeager535's Avatar
Car: Which one?
Engine: 355
Transmission: 465
Thinking new=good IMO is wishful thinking.
I never replace known good components with "new" just because I'm in there. At least with "used" lifters, you *know* they work!
No offense to anyone, just my opinion based on watching so many people have problems with "new" parts. You can't get much better than OEM on most stuff, at least before they started farming replacement stuff out to Taiwan.
For OEM being better, witness comps roller retrofit lifters...no prolonged idle?? I don't recall that in GM's literature.
Old Aug 18, 2008 | 01:10 AM
89RsWestTexas's Avatar
Car: 89 Rs
Engine: 305 Lo3
Transmission: t5
Re: reusing lifters?
I'm new to the site, but from what I've heard if you are going to reuse the hyd. rollers you have to bleed the oil out??? Is that correct?
Old Aug 18, 2008 | 10:06 AM
dyeager535's Avatar
Car: Which one?
Engine: 355
Transmission: 465
No reason that is NECESSARY, but perhaps whoever said that means to do so to make sure they are clean internally? Dunno.
Old Aug 19, 2008 | 05:07 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
On the several stock/semi-stock engine builds i've done i've always re-used them.
I soak 'em in gas and then swish 'em around. Let 'em dry. Then soak 'em in oil for a couple of days before re-installing them.
No problems yet.
The odds are in your favor.
b4ccamaro
Jun 5, 2016 01:48 PM
skinny z
Oct 5, 2015 06:23 PM
WhteRbt
Sep 21, 2015 09:48 AM
dimented24x7
Sep 6, 2015 03:51 PM
