fuel pressure regulator oops maybe?
Old Jun 24, 2004 | 09:40 PM
1992rs/ss's Avatar
Car: 92 RS, 05 GTO (sold), 10 TL AWD
Engine: 383 HSR w/DSC1
Axle/Gears: Strange S60/3.73
so I was putting my new adj. fuel pressure reg. on and the diaphram came off the housing. pulled a little too hard to quickly. I laid it back down and put the new housing over it, but since the car is apart for the swap I have yet to put pressure through it yet. is this bad? in other words am I about to have a very leaky regulator?
Old Jun 25, 2004 | 03:27 AM
Morley's Avatar
If you pulled the diaphram loose from the center piece with the spring under it you can throw it in the trash. The diaphram is supposed to be crimped and bonded to the center piece.
Old Jun 25, 2004 | 05:15 PM
1992rs/ss's Avatar
if it is trash now what can I do to fix this? where can I get a new one? need some help here.
Old Jun 26, 2004 | 01:58 AM
Morley's Avatar
Contact the regulator mfg. Also check with the dealer, some adjustables use a stock diaphram.
Old Jun 26, 2004 | 02:25 AM
1992rs/ss's Avatar
hmm, I guess I should maybe clear up this situation I know what people are talking about. I pulled the cover off as I am using a BBK adj. which is just a new cover with the screw in it, it reuses the stock internals. I pulled to hard and the pink diaphram peeled off the metal block that is the bottom of the regulator. spring and every thing came with it too, all that was left was the bott block. the the spring and metal rod on the side stayed together with the outside diaphram with no ripping. now correct me if I am wrong but isn't this how they put it together? or is the diaphram stick down with a adhesive to the metal base? it would seem to me that is I got a new reguator I would still be using that metal base that is a part of the fuel rails right? I hope this gives a clearer understanding of what my problem is. that way I will understand your replies a little better.
Old Jun 26, 2004 | 04:34 PM
Morley's Avatar
Correct, that is the way they are put together. The diaphram was cold welded to the regulator base from time and heat. As long as it didn't tear it is ok.
Old Jun 27, 2004 | 10:03 PM
1992rs/ss's Avatar
sweeeeeeet thanks a lot
MustangBeater20
Oct 29, 2022 09:20 PM
9192camaro
16
Feb 3, 2019 12:21 AM
wayshegoes
Aug 17, 2015 12:00 PM
89-S-dime
Aug 12, 2015 11:57 AM
Kaweh
Aug 9, 2015 02:54 PM
