Free Mods
Old Jul 5, 2004 | 02:08 AM
Strunthopht's Avatar
Free Mods
Can someone give me a rundown of most/all the free mods?
I mean like, Adj. Fuel Pressure Reg, remove MAF screen, timing chain?, you know.. the little things.
Old Jul 5, 2004 | 04:25 AM
steven90GTA's Avatar
From: Tomball Texas, right outside (north) of Houston
Car: 1990 GTA and 83,99,02 Trans Am WS6
Engine: 350 TPI,CrossFire 305 and LS1
Transmission: 4L60 and 700R4 and 4L60E
Axle/Gears: 90-3.23,83-3.42,99-3.73,02-3.42
You don't have any MAF screens to remove, only on 85-89 cars
Old Jul 5, 2004 | 11:46 AM
MdFormula350's Avatar
free / close to free mods are timing bump and coolant throttle body bypass. shaving weight off the car.
cheap mods: throttle body airfoil, high flow air filter (or a homemade cold air intake). fuel pressure regulator.
Old Jul 5, 2004 | 12:08 PM
DuronClocker's Avatar
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
Does the tb coolant bypass have any noticeable effect? And is there a way to make the stock TPI fpr adjustable like you can do on the TBI models?
Old Jul 5, 2004 | 03:53 PM
robsgta's Avatar
Car: 88GTAnotchbac/91 -Z/66 Chevelle
Engine: All strokers
Transmission: Pro built 700r4's
mods
Timing chain is a big job..If your going to do that you might as well up grade the cam.
you can port your plenum
Old Jul 5, 2004 | 07:17 PM
White91GTA's Avatar
Car: 1991 Trans AM GTA
Engine: 5.7L TPI
if you don't have emissions to worry about, then remove the cats and all of the AIR system, delete the EGR, 180* t-stat.
sorry to jack your thread, but does anyone have a more detailed picture of how to do the TB bypass? the pic in the tech article is kind of confusing and hard to understand.
Old Jul 5, 2004 | 07:36 PM
vwdave's Avatar
I cut off the bottom of my panel filter holders.
Old Jul 5, 2004 | 08:44 PM
Old Jul 5, 2004 | 09:10 PM
White91GTA's Avatar
Engine: 5.7L TPI
Originally posted by MdFormula350
can you explain the procedure on that...i like your pic a lot better than the one in the tech article. did you just get something to put in between the 2 hoses and then block off where the hose on the bottom passenger side of the throttle body goes?
Old Jul 5, 2004 | 09:38 PM
fireball451's Avatar
Car: 91 Z28, 91 Z28, 92 Z28
Engine: LB9, LB9, L98
Transmission: T5, T5, 700r4
Axle/Gears: 3:42, 3:42, 3:23
When I did my throttle body by-pass, I just used a molded heater hose that had a 90 degree bend. Just be careful with the heater valve. They become brittle with age and could burst.
Old Jul 5, 2004 | 11:53 PM
Dr.NickRiviera's Avatar
Car: 1987 Trans Am
Engine: tree-fiddy
throttle body bypass is easy. Go to the auto store and get a 3/8" hose coupler.
Disconnect the coolant lines from the thottle body on the passanger side, and on the bottom of the TB. Connect the hoses with the coupler and tighten the clamps that should already be on the hoses. Once you look at it in person it will be clear.
You can also just get a 8-10" piece of hose and connect the heater valve thing-a-majig, to the coolant nipple on the manifold.
Old Jul 6, 2004 | 12:07 AM
kid camaro's Avatar
Car: 91 z28
Engine: 305 tpi
how do you delete the egr?
Old Jul 7, 2004 | 05:50 PM
White91GTA's Avatar
Engine: 5.7L TPI
Use the SEARCH function
Old Jul 7, 2004 | 06:38 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
or buy an egr block off plate, or unplug the egr and plug it with a screw
Old Jul 7, 2004 | 07:09 PM
NastyL98_T/A's Avatar
Car: '88 T/A and '90 T/A
Engine: LB9/383
Transmission: T5/700R4
all the free mods are pretty much un-noticeable unless you do them all. Maybe a tenth.
Old Jul 7, 2004 | 08:14 PM
kid camaro's Avatar
Car: 91 z28
Engine: 305 tpi
the search function usually doesnt work for me.
Old Jul 7, 2004 | 08:36 PM
White91GTA's Avatar
Engine: 5.7L TPI
that is a personal problem...i found everything i needed to know about deleting the egr by using the search function
Old Jul 7, 2004 | 09:05 PM
White91GTA's Avatar
Engine: 5.7L TPI
MDFormula350...which of the ports on the bottom of the TB does the hose need to be connected to when doing the TB Coolant Bypass? I know one end of it hooks to the heater control valve, but am not sure on which of the other 2 ports to use. Thanks for the pic and all the help.
Old Jul 7, 2004 | 09:24 PM
LAFireboyd's Avatar
Axle/Gears: 9-bolt/3.45
Do you still have, or at least remember, the U-shaped hose that went from the front of the intake manifold up to the lower front of the throttle body? The coolant direction is OUT from the lower fitting(intake manifold) and up INto the throttle body fitting, then OUT of the passenger side throttle body hose fitting and INto the heater valve.
Pull the U-shaped hose, if you haven't already, and pull the hose from the side of the throttle body to the heater valve. Then connect your new hose from the intake fitting straight to the heater valve. So there will end up being no coolant hoses connected to the throttle body when you're finished.
Old Jul 7, 2004 | 09:58 PM
kid camaro's Avatar
Car: 91 z28
Engine: 305 tpi
well excuse me mr wonderful. would you like a cookie for being so self sufficient? ya dont need to be a dick about it.
Old Jul 8, 2004 | 01:07 AM
Car: 1997 Corvette
Take it easy, its what everyone says to people here who don't know how to search. It always works, you just have to know what you're looking for, and if you don't, its "your" problem, hence the "personal" problem.
Anyways, where can one pick up this hose with the 90* bend in it? I want to do this mod, more or less just so I have one less connection to the throttle body to worry about when I remove it to clean it and install my LT1 intake when it arrives
Old Jul 8, 2004 | 08:55 AM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
You can get them at any parts store (though you might have to walk back and get it yourself after the parts monkey looks at you funny for asking for a piece of 5/8" heater hose with a molded 90* bend).. Usually they'll have ones with about a foot of straight hose after the bend and you can just cut to fit...
Old Jul 8, 2004 | 11:20 AM
Car: 1997 Corvette
Okay, cool. I should probably buy a new upper and lower radiator hose while I'm at it.
Old Jul 8, 2004 | 04:56 PM
Engine: LB9/383
search button sucks on this board. Too many stupid, irrelevant posts to dig through.
All you need to do to bypass the TB is pull the U-shaped hose off of the intake and TB......now throw it away. Next, take the coolant hose off of the side of the TB but leave the other end on the HCV. Now find a hose to bridge the gap between the intake manifold and the hose coming off of the HCV. Very simple 10 minute job with no rocket science involved.
Old Jul 8, 2004 | 05:32 PM
White91GTA's Avatar
Engine: 5.7L TPI
thanks guys...that is the port that i thought was still used, but wanted to make sure before i start the "project"
Hotrodboba400
Dec 10, 2019 07:07 PM
ZZ3Astro
Aug 13, 2019 12:57 AM
Nervous2
Oct 8, 2015 10:53 PM
NastyEngines
Group Purchases
Sep 8, 2015 10:14 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
