TPS Sensor plug?
Old Jul 14, 2004 | 05:45 PM
ChevelleFan's Avatar
Car: '70 Chevelle, '63 Corvette
Engine: 383, 327
Transmission: B&M 700r4, Muncie M-21
TPS Sensor plug?
I'm swapping a TPI into my Chevelle.
Is there any other car besides a 3rd-gen TPI that I could use as a source for the TPS' sensor connection? (the 3-wire plug). I'm building my own wiring harness for a MegaSquirt controller.
Thanks,
-Dave
Old Jul 14, 2004 | 09:33 PM
DoBeR's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Transmission: 4 Spd Auto
Im pretty sure the corvette would have the same plug.
Old Jul 14, 2004 | 10:24 PM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
You could also use any number of other different GM applications... The 3 wire connector like on the TPS is pretty standard and is used on many cars/trucks...
EDIT: You should be able to go to a good parts store (napa/carquest) and order the gm weatherpack connector components individually (connectors, pins, etc)
soarestransam
Aug 24, 2015 08:15 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
onebadazzsrt
Aug 15, 2015 07:00 AM
fonzie85
Aug 13, 2015 11:50 AM
