adjustable fuel pressure regulator
Car: 1988 Iroc Z
The guy I purchased the car from says it has a TPIS adjustable fuel pressure regulator. I just need to know where its at...I think I found it. I'm pretty sure its right in front of the distributor,behind/under the intake? If it is, do I have to take the intake off to get at it? Thanks for the help, sorry if its in the wrong forum.
Car: 1985 IROC-Z
Engine: 5.0L TPI
Transmission: TH700R4
It is located in front of the distributor. It looks round with 6 torx screws holding it down. You will need a special torx driver to remove it since it has a little nipple in the center of the screw. To get access to it, you will have to remove the plenum.
Car: '91 Formula
If all you want to do is adjust the fuel pressure, there should be a nut in the middle of the regulator that you can turn with a box wrench. I have the Holley AFPR with the dial on it, so I don't have to use a wrench, so I'm not sure if getting a wrench in there is possible with the plenum on. Should be though.
9192camaro
16
Feb 3, 2019 12:21 AM
