305 tpi plans
Old Jul 17, 2004 | 12:13 AM
springfield's Avatar
Car: 1992 camaro rs 25th anniversary
Engine: 305 tbi
Transmission: 700-r4
305 tpi plans
does anybody out there have a reasonable estimate for the power output of this engine or have real numbers from a similar engine?....
stock 92 305 tbi, converted to tpi
edelbrock runners and baseplate
edelbrock heads
streetable cam
twin 58mm throttle body
air intake
exhaust
if anybody has an idea that would be awsome, thanks
Old Jul 17, 2004 | 12:26 AM
DuronClocker's Avatar
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
For ***'s sake, don't upgrade the throttle body.
Old Jul 17, 2004 | 01:51 AM
rockind78's Avatar
Agreed. Spend the extra $200-$300 on something else.
Old Jul 17, 2004 | 07:06 AM
Car: 1997 Corvette
Like datalogging and PROM equipment You'll get a lot more power out of that than any throttle body upgrade. Or if you don't want to mess with that kind of stuff, go upgrade your suspension. You could get an adjustable torque arm for about the same price, or you could go with SFCs, LCAs, and LCA relocation brackets all together for a few more dollars. You'll notice far more of a difference doing that stuff than upgrading the throttle body..
Or start saving for a 350 In fact, I say get rid of the long tube runner setup. Get a miniram or stealthram setup, and then spend the $300ish you save on the throttle body upgrade to buy a 350 motor, and buy some AFR heads instead of hte Edelbrock ones (I don't know the price difference, but I know AFRs are expensive!) and bolt those to your 350 block, and then you'll have one hell of a setup
Old Jul 17, 2004 | 09:24 AM
91RS5speed's Avatar
Car: 91 RS
Axle/Gears: Auburn Pro / 3.42
I got dyno graphs of my swap on basicly stock 305 tbi to tpi
Old Jul 17, 2004 | 07:51 PM
Engine: 305 tbi
how much would the tbi to tpi swap costto get it completely done and running, anybody know?
Old Jul 19, 2004 | 09:01 AM
N8MAN1068's Avatar
Car: 85 ta ws6 KITT
Engine: Lb9
Transmission: th350
kinda hard to give an estimate without knowing the exact cam specs and heads.
Orr89RocZ
Apr 25, 2016 08:28 AM
gta90
Sep 15, 2015 04:00 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 6, 2015 04:20 PM
