Initail Start Up
Old Jul 18, 2004 | 05:05 PM
360Iroc's Avatar
Initail Start Up
Hit the key today, and the car fired right up as if there was never an engine swap done. the only problem is, it on ran for a few seconds. the engine start right up revving to 1100 then when it comes back down to catch an idle it dies. does anyone have any ideas as to what causes this?
any help would be greatly apprieciated.
Old Jul 18, 2004 | 11:22 PM
Scott57350's Avatar
Car: 1991 Z28
Engine: 355 TPI
whats your mods and are u running stock chip with an aftermarket mods like heads, cam . or injectors???. more info is needed
Old Jul 19, 2004 | 05:59 AM
PF Flyer's Avatar
Car: 87 T/A
Engine: TPI 350 ci
Transmission: 5 speed
if you're still runnng a TPI setup, it could be as simple as the TPS (throttle positioning sensor) needs adjusting.
Old Jul 19, 2004 | 07:04 AM
360Iroc's Avatar
350 .060 over comp cams 264 grind not sure of lifts any more. world torquer 2 heads, 1.6 rollers
tpi
jet chip
thats it
thanks for any help
Old Jul 19, 2004 | 07:58 AM
conrad_6699's Avatar
Car: 1987 Trans Am Gta
Engine: 305 tpi
Transmission: stock tranny
in my 87 gta if i don`t wait a few seconds after i turn it on before i hit the starter it will die i think its because of fuel pressure but i`m new here so i may be wrong
Old Jul 19, 2004 | 08:01 AM
360Iroc's Avatar
double post
360Iroc's Avatar
ive got 48 pounds of pressure. its not a fuel delivery problem.
Old Jul 19, 2004 | 11:44 PM
360Iroc's Avatar
seems like no one knows what the problem is
vacuum leak was the problem
Orr89RocZ
Apr 25, 2016 08:28 AM
Wade787b
Sep 29, 2015 01:15 PM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
92camaroJoe
Aug 13, 2015 06:07 AM
86Base
Aug 8, 2015 01:34 PM
