Bad TPS???
Old Jul 20, 2004 | 10:13 PM
DoBeR's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Transmission: 4 Spd Auto
Bad TPS???
On the weekend I tried to see if my TPS was properly setup so I did as the tech page said and use jumper wires and a voltmeter to get readings with the ignition on. Measuring off the top 2 wires I got .26 volts, but when I rotated the sensor, the voltage didnt change. Also when I opened the throttle blades, the voltage didnt change either.
Am I doing something wrong or do you think my sensor is just gone?? Would the car still operate alright if the sensor wasnt working properly??
Old Jul 20, 2004 | 10:48 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
I'm not sure how you had the jumper connected but what you can do is take two paper clips or sewing needles. Stick one in the back of the TPS connector at the top and center pin without disconnecting the connector. Turn the key to the on position and measure the voltage that way. Remember, top is negative and center is positive. Just a thought!!!!!!!!!!!!
Old Jul 20, 2004 | 11:18 PM
CaptPicardsZ28's Avatar
Car: NCC-1701-D (docked in AZ)
Engine: impulse drive
Transmission: fusion reactors
Axle/Gears: Rescued from the Borg by my crew
Re: Bad TPS???
Try this link and do it again. You may have a bad tps. It doesnt take much for it to adjust. This link has pics.
http://www.iroczone.com/techarttpsadj.html
Old Jul 21, 2004 | 09:55 PM
mike316's Avatar
Car: 1986 Camaro IROC-Z
Engine: 350TPI
Transmission: TH350 w/Stall & Shift Kit
When I was messing around with mine trying to get it right my car ran like **** until I got it right.
92firebirdguy
Sep 1, 2016 07:53 AM
BumpaD82
Feb 26, 2016 02:57 PM
3rdgenkindagal
Sep 13, 2015 02:02 PM
earlpote
Sep 12, 2015 11:55 AM
