Pressure Regulator
Old Jul 25, 2004 | 05:46 PM
klystron's Avatar
Car: 87 IROC
Engine: 350cu.
Transmission: 700-R4
Pressure Regulator
I installed Crane Cams Adjustable fuel pressure regulator on my
87 IROC 350cu. I followed the instructions exactly. The screw they use seems way too long it hits the plenum way before your down to stock pressure 42psi. I had to cut more than half off it off to use it. Has anybody installed this on there car and had the same problem?
Old Jul 26, 2004 | 09:08 PM
89Warbird's Avatar
Car: 1989 GTA Nighthawk
Engine: 389 CID TPI
Transmission: TCI 700R4
Axle/Gears: 9 bolt 3.23
I didn't have that problem with my Crane, it is a long adjusting screw. I did add a nut so I could lock the screw in place at a set pressure.
Old Jul 27, 2004 | 08:05 AM
88305tpiT/A's Avatar
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
Do a search for this and I think you will find that many of the aftermarket AFPR makers have this problem. I bought a BBK and will put it on my car soon and did a search. Apparently the Holley unit is the only one that doesent have this kind of problem.
Old Jul 27, 2004 | 08:18 AM
87tpi's Avatar
Car: 00 Camaro SS
Engine: 5.7
Transmission: 6 speed
My bbk was the same way.Just cut the bolt down.
Twin_Turbo
Mar 14, 2016 10:10 PM
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
m00n420
Sep 11, 2015 02:39 PM
lakeffect2
Sep 7, 2015 03:52 PM
Strick1
Sep 4, 2015 07:11 AM
