engine pic
Old Jul 27, 2004 | 07:48 PM
mike88form350's Avatar
Car: 88' Formula 350
Engine: 358 ci TPI
Transmission: Tremec T-56
engine pic
358 ci engine for my firebird
Old Jul 27, 2004 | 07:50 PM
Engine: 358 ci TPI
pic looks like crap. anyone good at editing these things to the correct file size and still having them look good?
Old Jul 27, 2004 | 08:07 PM
DoBeR's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Transmission: 4 Spd Auto
Email them to me if you want ill try to edit it.
dober@aci.on.ca
Old Jul 27, 2004 | 08:31 PM
Engine: 358 ci TPI
tried to send don't think it worked though. files may have been to big. i'll try again
Old Jul 27, 2004 | 09:58 PM
DoBeR's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Very nice looking engine!!!
Old Jul 27, 2004 | 10:05 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Nice looking engine!
Originally said by my girlfriend, who is browsing with me:
Aww he even shinyed the bronze disks! *points to freeze plugs*
Care to share about it's build up?
Old Jul 27, 2004 | 10:13 PM
THEGENERAL's Avatar
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
very nice engine and as stated above whats it got inside ???
Old Jul 27, 2004 | 10:32 PM
jbbiggs's Avatar
Car: 95 formula
Transmission: 4l60e
Don't scratch it puttin it in....
Old Jul 28, 2004 | 12:20 AM
evelkneivel001's Avatar
Car: 87 GTA
Engine: 383 Stroker
Transmission: 700 R4
Damn nice looking job!
I'm in the process of putting my 87 TPI together and I hope it looks half as good as yours. I'm curious, which cam are you running and heads also? Most of all, where did you get those nice plug wires? They are the shat!:hail:
Old Jul 28, 2004 | 03:39 AM
nick418's Avatar
Engine: L98, Hemi 6.2
damm that looks sweet
Old Jul 28, 2004 | 08:19 AM
Engine: 358 ci TPI
thanks guys, and thanks to DoBeR for posting a much better looking pic than my original.
the engine is a 4 bolt corvette block balanced and blue pirnted to very nice specs
the my goal with this engine right now is to hit low 13's on a stock intake and cam...13.4 i would be very happy with. i need the car back on the road so the build up is not to crazy. also had a tight budget to get the whole car done.
the heads are stock cast iron fully reconditioned, 3 angle valve job, new valves springs, seals.
the plug wires are GM performance parts with moroso looms. i will post more specifics later. right now i have to get back to class. thanks for the complements.
Old Jul 28, 2004 | 10:11 AM
5SIZ's Avatar
Car: 1987 IROC-Z
what kind of wire holder are those?
Old Jul 28, 2004 | 06:23 PM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
Transmission: So close to being a manual I can taste it
What does that say on the fuel injectors? Siren?
Looks great!!
Old Jul 29, 2004 | 04:44 PM
Engine: 358 ci TPI
The injectors say Marren on them for Marren Fuel Injection. www.injector.com
only $200 bucks for the set of matched and blueprinted injectors.
Old Aug 3, 2004 | 03:40 PM
Stingraye's Avatar
Car: 1986 Trans Am
Engine: 350 W/Plenty of Mods
Looks like CRAP. Probably gonna be slow as ***** too..... oh well, to each his own.
Old Aug 3, 2004 | 04:38 PM
level's Avatar
Car: 1987 transam
Engine: 383 /w superram
Transmission: 700r4 /w 2800rpm stall
wtf, that wasn't to nice.. i think it looks great my block is rusting already
Old Aug 3, 2004 | 04:58 PM
THEGENERAL's Avatar
thats funny ....looks dont mke it slow or fast ......
Old Aug 3, 2004 | 05:01 PM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
Nice engine, I think you have the spark plug wire brackets mounted upside down. I think the wires are supposed to go along the bottom side of the valve cover not the top next to the runners.
Old Aug 3, 2004 | 06:18 PM
Stingraye's Avatar
Car: 1986 Trans Am
Wow, guess no one on this board has ever heard of sarcasm before... sorry, didn't realize you guys live on the far side of the earth.
BTW, I'm good friends with mike, and he knows i'm just bustin his *****.
Old Aug 3, 2004 | 07:11 PM
THEGENERAL's Avatar
sorry but there are alot of a holes on this board .....lol....
Old Aug 3, 2004 | 07:17 PM
Stingraye's Avatar
Car: 1986 Trans Am
Good point. All's good.
Old Aug 4, 2004 | 03:20 PM
Engine: 358 ci TPI
dan and i have been good friends for...gosh must be 4 years now. we poke fun at eachother all the time, helps to keep us in check.
89 Iroc Z, you might be right about the wire looms, i just put them on to mock it up for the picture, but i think it will still work that way, i placed them so the end runner goes in between the two looms and the front one wont be anywhere near it. the dam air diverter should fit right in the middle blocking out the nice bow tie. how i will run them once the engine goes in the car i have no idea, but i hope it will look similar.
Old Aug 4, 2004 | 03:26 PM
crazy3rdgen's Avatar
Car: 2002 SS
Engine: Ls1
Axle/Gears: 3:42 posi
looks pretty good cant wait to see what the dyno says....
Engine: 358 ci TPI
the whole passenger side of the engine compartment is so cluttered up with A.I.R., heater, and AC hoses on tpi cars. it's kind of anoying when you try to put together nice looking engine and half of it gets blocked out by other things. oh well, thats just the way it goes i guess.
Old Aug 4, 2004 | 03:27 PM
Engine: 358 ci TPI
Tremec t-56.
Old Aug 4, 2004 | 03:29 PM
Car: 2002 SS
Engine: Ls1
yeah mike sry bout that i was looking at dober
Old Aug 4, 2004 | 03:34 PM
Engine: 358 ci TPI
thats ok, i love your wheels. the zo6 rims look amazing on camaros.
Old Aug 5, 2004 | 10:16 AM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
Your wires will roast that way. I had the edelbrocks and even used heat sleves but they all got to wires on the pass side. ONLY way I didnt burn them was to run them under the header.
Old Aug 5, 2004 | 03:09 PM
Engine: 358 ci TPI
yeah, i've burned through plenty of wires before. i ran the wires that way so it would look pretty for the pic, thats all.
Reddeath210
Oct 6, 2015 08:20 AM
project89
Sep 24, 2015 06:38 AM
Linson
Aug 21, 2015 02:12 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
BrianI
Aug 9, 2015 11:52 AM
