fuel rail injector retainer clips
Old Jul 30, 2004 | 12:23 PM
AGDrake57's Avatar
Engine: 88 350 TPI
Transmission: TH400
Is there a trick to removing the sickle clips that hold the fuel injectors within the fuel rail?
I couldn't seem to figure out how to remove the clip, I don't want to tear anything up, any advice or help is appreciated
Thanks!
Old Jul 30, 2004 | 12:26 PM
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
Do you mean the turning of them so you can remove the injectors?
Old Jul 30, 2004 | 12:34 PM
AGDrake57's Avatar
Engine: 88 350 TPI
Transmission: TH400
That must be it. Do you rotate the injector, or clip, or both?
Thanks again.
Old Jul 30, 2004 | 12:40 PM
vernw's Avatar
Just the clip. There is a "longer" leg on the clip that should be up against the rail. Slide/rotate that long leg around the injector to the rail on the opposite side of the injector and then the injector should pull out (or in some cases fall out - depending on how good the o-rings are)
Does this help?
Old Jul 30, 2004 | 12:43 PM
AGDrake57's Avatar
Engine: 88 350 TPI
Transmission: TH400
Originally posted by vernw
Does this help?
Yes, most definitely, Thank you.
Andrew6.688
Dec 13, 2015 10:59 AM
sweet_87_iroc
Sep 25, 2015 10:01 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
92projectcamaro
Aug 6, 2015 01:20 PM
