Cold Start Injector leak?
Old Jul 30, 2004 | 05:49 PM
TPI Monte SS's Avatar
Car: 1988 Monte SS
Engine: ZZ4-cammed TPI 355
Transmission: World-Class T5
Hi all,
After putting about 300 miles on my car since I installed the SLP runners, I noticed some fuel stains on the lower manifold by injectors 5/7, and the feed line for the cold-start injector is damp with fuel. I know I tightened the fitting at the back of the fuel rail that feeds the CSI, and the O-ring seemed allright, so I reused it.
Is there a special way to tighten the fitting? Any other suggestions where it could be leaking from?
Old Aug 3, 2004 | 10:43 PM
Car: 1988 Monte SS
Anyone have a suggestion?
Old Aug 4, 2004 | 10:44 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
I'd just eliminate it and run a chip from an 89.
Old Aug 4, 2004 | 11:41 AM
87camaroz28310's Avatar
Car: 87 plane jane with gfx
Engine: 350 worked vortec head .515 .515 cam and 1.6 rockers and shorties for now til i can afford the supercomps
Transmission: super t-10 or t-5
Axle/Gears: auburn with 3.42 stock axles
ihave actually tried to get one from a gm dealership and you cant. they're discontinued. so i would go with what jim said or try to find one in a jusnk yard.
Old Aug 4, 2004 | 10:26 PM
Car: 1988 Monte SS
Thanks Jim. What do I do about the '89 VATS? Or would I need to have a chip burned to take care of that?
jklein337
Sep 19, 2018 06:23 PM
Wade787b
Sep 29, 2015 01:15 PM
mizz0313
Aug 12, 2015 06:45 AM
mustangman65_79
Aug 8, 2015 12:07 PM
drathaar907
Aug 6, 2015 04:20 PM
