Heads setup for Solid roller, what to change for hydraulic roller (valvesprings & ?)
Old Aug 2, 2004 | 11:47 AM
Mike86Z28's Avatar
Car: 98 Z28
I have some Afr 195's that were setup for a solid roller cam. Since I am going to put them on my L98 (hydraulic roller cam), what do I need to change on the heads besides the valvesprings? I was probably going to run a XR276HR cam (.503/.510 w/ 1.5 rocker).
Thanks in advance.
Edit - It's probably unimportant but the heads have 7/16" studs and 68cc.
Old Aug 2, 2004 | 12:59 PM
Mike86Z28's Avatar
Car: 98 Z28
Does this sound right?
Comp 977 valve springs/recommended locator/titanium retainers ?
That's what the guys at Thunder Racing told me I needed to change on the Afr's so I can run the XR276
Old Aug 2, 2004 | 09:50 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Try the Comp 987's. The seat pressure on the 977s at the given installed height are a bit high. Shim the springs if needed to get the appropriate installed height.
Terrell351
Jun 13, 2021 01:13 PM
midge54
Dec 27, 2019 04:14 PM
junkcltr
Aug 2, 2019 11:12 PM
Street Lethal
Aug 13, 2015 08:28 PM
anesthes
Aug 8, 2015 09:37 PM
