HSR & TB bolts
Old Aug 5, 2004 | 06:04 PM
jamesbob02's Avatar
Car: 92 Z28
Engine: 357 TPI (L98)
HSR & TB bolts
I wouldn't have posted this if I found the answer, but I couldn't, so I thought I'd ask.
I read a long while back about there being a possible conflict with the stock throttle body bolts not threading into the HSR because one was metric and the other was english, although this varied from year to year or something, so its not a common problem.
I've got a 92 TPI, and was wondering if I could expect that problem, and if so, what is the correct bolt (diameter, thread #, and length) to install the TB to the HSR?
Thanks guys.
Old Aug 5, 2004 | 06:14 PM
Synapsis's Avatar
Car: Sexy
Engine: Stock
Transmission: Slipping
Stock bolts fit fine.
Old Aug 6, 2004 | 08:12 AM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
the tb bracket bolts were a different threading than the stock bolts on the hsr's i've installed.
Old Aug 6, 2004 | 10:54 AM
Synapsis's Avatar
Car: Sexy
Engine: Stock
On a 1990 plenum, they went in fine. Then when I installed my nitrous plate, the bolts supplied were the same thread but longer... also went in fine.
Maybe GM switched the threads or something over the years.
Old Aug 6, 2004 | 11:37 AM
Car: 1988 IROC-Z
doubtful GM changed the bolts..... perhaps holley changed things around. just like different revisons of the HSR. that's more believeable?
Old Aug 6, 2004 | 08:31 PM
Twilightoptics's Avatar
Car: '87 IROC-Z/'82 RX7
Engine: SBC 355/1.1L Rotary
Transmission: T56/5 Speed
Axle/Gears: 4.33/3.93
My TB bolts fit fine... I had to get 3 new bolts for where the throttle CABLES attach to the plenum.
These bolts have bolted to an '85 TPI plneum, '87 TPI plenum, and now the HSR.
Old Aug 6, 2004 | 09:57 PM
jamesbob02's Avatar
Car: 92 Z28
I've got a 92....has anybody installed a 90+ TB on the HSR without problems?
Old Aug 7, 2004 | 02:02 AM
Synapsis's Avatar
Car: Sexy
Engine: Stock
Yes.
Old Aug 7, 2004 | 02:17 AM
jamesbob02's Avatar
Car: 92 Z28
Sweet.
What did you use for a wateneck? I read a guy said he used his stock 92 just fine, but looking at my car it seems impossible.
Also, I've read a lot that the Mr Gasket one warps and is useless. What did you do?
Old Aug 7, 2004 | 02:25 AM
Synapsis's Avatar
Car: Sexy
Engine: Stock
I currently have the warped and useless Mr Casket.... complete with water stains under it.
Old Aug 7, 2004 | 02:40 AM
jamesbob02's Avatar
Car: 92 Z28
Figures.
What are you going to try now?
Old Aug 7, 2004 | 10:03 AM
Car: 1988 IROC-Z
use the water neck off a 305 tbi motor. get it from the salvage yard. the parts stores stock the one with all the "holes" on top of it. i then used a 86' carb upper radiatior hose. it works fine and looks stock.
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
86CamaroDan
Sep 29, 2015 10:08 PM
Jlanz55
Sep 6, 2015 07:28 PM
355tpipickup
Sep 4, 2015 05:32 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
