Where to set timing "for now"
Old Aug 6, 2004 | 09:36 PM
Abubaca's Avatar
Here's the deal:
I've got my ZZ4 cam and headers installed, on top of several other little things. I've earballed the timing so far, and it runs well, but this weekend I'm gonna use my BRAND NEW timing light and do it right!!! Problem is, where is right?
I'm having the car dyno tuned and having a chip burned by a local FI guru in a few weeks, but I wanna have it running pretty good from now until I get the tune done.
I know 6* advance is factory, but I also know a lot of stock L98 guys are running around 8* or 9* for a little more kick. I honestly don't fully understand the theoretical effects of timing on a motor. Should I just keep it at around 6* and wait for it to be properly tuned, or should I just mess with it a little.
Just looking for opinions...
Old Aug 6, 2004 | 10:16 PM
BronYrAur's Avatar
Car: 91 Camaro RS Convertible
Engine: 305 TBI
Transmission: 5-Speed
What kind of car is this? Is it that L98 car in your sig, if not what's the setup?
Old Aug 6, 2004 | 10:41 PM
Abubaca's Avatar
....musta clicked tBi, not tPi.
This is not my forum, so I can't move it! Sorry guys, anyone wanna move this over to TPI?
...in the meantime, anyone have any thoughts???
Old Aug 6, 2004 | 10:48 PM
BronYrAur's Avatar
Engine: 305 TBI
I kinda figured that you clicked the wrong forum ha. I'm sure with that cam it'll want a few more degrees over stock, best would be to modify the bin. I'd say for now keep it maybe 4* over stock if it doesn't knock. Then make the real changes when you get it tuned on the dyno.
Old Aug 9, 2004 | 11:57 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
I will move it for you.
Old Aug 9, 2004 | 06:58 PM
AlexJH's Avatar
Engine: 5.7L V8
Don't lie to the ECM. If you're going to have it dyno tuned and a custom chip made, leave it at 6* and have the tuner raise the timing on the chip.
The reasoning is that there are calculations that the ECM does based on timing and you will get a better tune if your actual timing is the same as what is set in the chip.
PS. Remember to disconnect the tan/blk wire!
specialized
Jun 18, 2022 09:26 AM
Vintageracer
Jan 10, 2020 05:33 PM
midge54
Dec 27, 2019 04:14 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Andrew6.688
Dec 13, 2015 10:59 AM
