Running rough at startup.
Old Aug 11, 2004 | 09:55 PM
CogsRS's Avatar
Car: 87 Monte Carlo SS
Transmission: 200 4R
My car runs rough at startup, but then it runs fine after it warms up. Anyone know what this could be?
Old Aug 12, 2004 | 03:02 PM
omcrider's Avatar
Car: 1988 GTA
Engine: 5.7L/L98
Typically when this happens the CTS is the place to start. Your car runs in open loop until your temps reach about 150. In open loop the ECM is taking readings from your CTS to adjust AFR. Often people with the cold running stumble or rough idle can fix it with the replacemnet of the CTS.
Old Aug 12, 2004 | 03:30 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Are you running rich at all?
Old Aug 12, 2004 | 09:40 PM
CogsRS's Avatar
Not sure if I'm running rich or not. Does the CTS control the electric fan also? That doesnt turn on by itself. It's wired up by a switch.
Old Aug 12, 2004 | 09:57 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
The CTS does not control the fan. It gauges the engines temperature and tells the ECM what to do based on operational temps. Specifically, how much fuel. For example, if the CTS is reading lower than the actual temp, then it will the ECM "hey, engine is cold, inject more fuel." Thus, the ECM will tell the injectors to inject more fuel, moreso than what is actually needed, thus, making it run rich.
The fan switch (between #6 and #8 in the pass. side cylinder head) controls the fan.
customblackbird
Aug 15, 2021 10:16 PM
jbd1969
Aug 17, 2015 07:06 PM
Bradsaundry
Aug 12, 2015 12:34 AM
Sherpajames
Aug 7, 2015 06:56 PM
