heads for the 305
Old Aug 16, 2004 | 12:03 PM
swisscheese's Avatar
Car: '91 Z28
Engine: LB9
heads for the 305
Ok, as far as i read on this board there are not much out there for the 305.
the vortecs doesnt work for me because the manifolds wouldn't bolt up.
then there are the s/r torquer heads. they would bolt right up, but some say they need some work to flow any.
and the corvette alu-heads, with witch I would have to "reroute" the egr.
Can anybody enlighten me:
-if the torquer will need work to flow well?
-if the corvette heads would bolt right up, and how much of a trouble it will be to reroute the egr?
-if there are other heads witch I could use right out of the box?
(I read a $hitload of posts, and the more I read the more i'm ... )
Thanks for the help :hail:
Old Aug 16, 2004 | 02:24 PM
mikobu3's Avatar
port and polish your lb9's , put better springs , bigger 1.94 intake valves , also get a 3 angle valve job , i seen a article where they picked up 18.8 hp on stock ported heads but when the put bigger 1.94 valves the power increased to 24 hp , i am not sure if that is rear wheel hp ,
hope this helps
Jake_92RS
Jan 28, 2020 10:37 PM
gta90
Sep 15, 2015 04:00 PM
theurge
Aug 21, 2015 12:46 PM
