TBI/TPI Swap=No Heat or A/C
Car: 1992 RS (25 th Anniversary)
Engine: 350 Miniram XFI
Transmission: Pro-Built 4L60
Just like the title says, I have a 1992 RS that I swapped out the 305 TBI engine from and swapped in a 327 Miniram with the TPI wiring from a 1990 Camaro. The car runs great, everything works excellent except that I now have no Heat or A/C, the blower motor won't turn on. If you turn the heat on warm air will flow out only if you are driving and I can divert the air to defrost, vents, ect. , but no blower motor. I had Heat before the swap, now nothing. Anybody else have a problem like this !!!!
ambainb
Apr 25, 2016 09:21 PM
BikeFarm
Aug 11, 2015 11:35 PM
db057
Aug 11, 2015 10:11 PM
