any suggestions on this motor set up
Old Aug 18, 2004 | 05:03 PM
robleamy's Avatar
Car: 92 z28
i have a 92 Z28 and i got a new l98 short block from scoggin dicky i dont want anything too crazy just something that wont destroy its self when i give it some gas. so far i have the short block, a supper ram set up base, plennum and runners (got a good deal) some world heads 2.02/1.60 valves 67 cc chamber, 170 cc runners. and finally a 2032 powermax cam. i still have to buy the rocker arms, valve covers, timing cover, and timing chain, throttle body, injectors, and distributor. so i need suggestions on what i still need. once again i just want a streetable daily driver with some power. also im on a slight budget.
thanks Robert
Old Aug 19, 2004 | 01:21 AM
robleamy's Avatar
Car: 92 z28
it also needs to be cali smog legal
Old Aug 20, 2004 | 01:43 AM
89Warbird's Avatar
Car: 1989 GTA Nighthawk
Engine: 389 CID TPI
Transmission: TCI 700R4
Axle/Gears: 9 bolt 3.23
Underdrive pulleys, ceramic coated headers, they're worth it. What kind of heads? If they are S/R Torquers you might have a little problem with emissions, they aren't real clean burning heads.
Here's a link to the guy I bought my TB from, he makes good stuff and it's less expensive than anyone like BBK.
http://users3.ev1.net/~thor10/HP-FAQ.htm
Good luck with it.
theshackle
Sep 17, 2020 08:26 AM
theshackle
Mar 5, 2017 06:37 PM
TheExaminer
Aug 26, 2015 04:59 PM
InfinityShade
Aug 22, 2015 08:00 PM
Bradsaundry
Aug 12, 2015 12:34 AM
