Misfire on same cylinder...
Old Aug 19, 2004 | 09:08 PM
REALPOWER's Avatar
Car: 1984 Camaro on steroids/ 1987 iroc-z28 5 speed.
Engine: 383 nitrous motor / poindexter 305
Transmission: Th350
I have a misfire that is driving me UP THE WALL. When I first start the car, it misses on one cylinder. After it warms up, it fires on that cylinder, but only until I give it a little gas. It then misses until i let it idle again. Under heavy accelleration it doesn't miss.
I have replaced the plugs, all the top end gaskets(minus head) the wires look good and almost new and the motor doesn't make any noise.
I cannot tell which cylinder it is because when i try to diagnose it, it starts running correctly.
I am thinking bad injector, anybody else?
Old Aug 20, 2004 | 03:52 AM
Morley's Avatar
Re: Misfire on same cylinder...
That'd be my guess. When it does that again, shut it down and start pulling plugs and see if one is gas soaked.
Old Aug 31, 2004 | 10:52 PM
formulaman's Avatar
YOu can also pull injector wires to help diagnose
db057
Jan 10, 2020 08:55 PM
NZKnight
Oct 15, 2015 02:47 PM
camarohelp
Sep 22, 2015 03:19 PM
Jk_Under
Sep 8, 2015 08:13 AM
Thaney9
Aug 29, 2015 03:16 PM
