need help changing egr valve
Old Aug 28, 2004 | 02:29 AM
bad@ss89camaro's Avatar
Car: 91 Z/28 convertible
i have a 91 z28 convertible(tpi) and im pretty sure the egr is shot can any1 pls give me quick over view of how to change it whats the steps and how hard is it to change thanks
Old Aug 28, 2004 | 05:55 AM
thunderstick's Avatar
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
it's a piece of cake to change - BUT - you have to take the plenum off to do it. it sits on top of the intake, but under the plenum. if you're lucky, your plenum will come right off without destroying the gaskets and you can go right back on with it, otherwise you'll need those, too. it all has torx type bolts, and the egr has 10mm bolts.
KAM
Old Aug 31, 2004 | 10:10 PM
formulaman's Avatar
If you are very careful, you may be able to get the plenum off without loosening the runner to manifold bolts.
Out-Cast
Sep 3, 2015 09:05 PM
Out-Cast
Aug 17, 2015 10:57 AM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
