3rd gear request key on/limp mode start
Old Aug 28, 2004 | 08:00 AM
sparks454's Avatar
Car: 1987 GTA
Engine: 383 HSR Procharged
Transmission: TKO600
Axle/Gears: Moser 9", 35 spline Wavetrac 3.89's
I'm running an '87 GTA 350 tpi with 700r4 trans and 2400 lockup stall converter. When I turn on the key, I show a true flag using tunerpro for 3rd gear. Why 3rd gear and not 1st??? When the car is started it moves forward a little so that probably is the case that the converter is locked. Would this be the solenoid in the trans or the computer. I burn my own chips and this didn't start until yesterday all of a sudden.
Also, if i use winaldl to verify, it shows tcc locked when the key is on also.
Thanks,
Chris
eightsixseven
Dec 16, 2024 01:50 PM
drewdock87
South Central
Aug 18, 2015 09:02 PM
tnrednneck
Aug 13, 2015 08:57 AM
mizz0313
Aug 12, 2015 06:45 AM
