super ram worth 2-3 tenths?
Old Sep 2, 2004 | 02:03 PM
NastyL98_T/A's Avatar
Car: '88 T/A and '90 T/A
Engine: LB9/383
Transmission: T5/700R4
Trying to get the LB9 into the 13's this fall and I got a super ram sitting at the house. Just wonderin if the super ram setup with a BBK 58mm TB will be good enough or should I do some other tricks too Car went a 14.28 in good air at the beginning of the season. I'll be taking off the frot swaybar and running skinnies and a set of DR's.
Old Sep 2, 2004 | 02:44 PM
Paul Riccioli Jr's Avatar
Car: 89 IROC-Z
Engine: 383
I'd say you should have no problem hitting 13's by adding the Super Ram and getting a chip tuned for it.
Old Sep 2, 2004 | 05:59 PM
MdFormula350's Avatar
i say see what u can do with the swaybar off and full track rims and tires, before ripping intakes off.
Old Sep 2, 2004 | 07:10 PM
Mad-Mic's Avatar
Car: 87 Vette 85 TA 82 Z/28
Engine: 3 - 350's 388 400
Transmission: 2-700R4's 1 T56 Setup!
Axle/Gears: 2.59's 3.42's 3.73's
Re: super ram worth 2-3 tenths?
if you pull it let me borrow your runners
stick with the 48 mm TB cause i don't think that lil ole 305 will pull enough air for the 58 mm TB and you'll loose power.
Old Sep 2, 2004 | 08:55 PM
88TPI406GTA's Avatar
Car: 2009 Pontiac G8 GXP
Engine: LS3
Transmission: 6L80E
From your sig, it appears that you have stock heads...
If so, then a SR with a 305 will be overkill.
I would plan on some sort of head upgrade, either ported stock or aftermarket...before worrying about the SR.
A modded TPI setup with a 48-52mm TB would be plenty until you get decent heads....
Old Sep 3, 2004 | 07:29 PM
Ragtop89's Avatar
With 350, cam and SR I was able to run mid-13s on a stock chip with a failing fuel pump.
Old Sep 3, 2004 | 08:57 PM
Engine: LB9/383
Im gonna see how fast it'll go the way its set up now. Pull off the front swaybar and put the skinnies up front. I'm just gonna put the AFR headded L98 in the red car and go 12's.
Old Sep 4, 2004 | 02:13 AM
1992rs/ss's Avatar
Car: 92 RS, 05 GTO (sold), 10 TL AWD
Engine: 383 HSR w/DSC1
Axle/Gears: Strange S60/3.73
if you already have the SR setup sitting at home and it will cost you nothing to switch might as well do it and if that isn't enough for you then spend the money towards heads and other parts. the best mods are the free ones. I know that it will be the heads that are the restriction, but opening up the intake will do at least a little for you.
Old Sep 4, 2004 | 01:46 PM
87350IROC's Avatar
Car: 87' IROC
Or you can give me your super ram.
Old Sep 5, 2004 | 10:26 AM
Engine: LB9/383
roflmfao
Linson
Oct 24, 2025 02:00 PM
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
no green
Jan 9, 2016 09:22 PM
bjpotter
Oct 4, 2015 07:48 PM
gord327
Oct 3, 2015 01:25 PM
