bad water pump (i think)
Old Sep 9, 2004 | 01:37 AM
bad@ss89camaro's Avatar
Car: 91 Z/28 convertible
my car is losing water and i found out that when i have the car running water is coming out a little hole in the water pump is there some way to fix that or do i have to get a new 1
Old Sep 9, 2004 | 02:19 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Yep, thats the weep hole. Pumps usually leak there when the inner seal or bearings go bad. Probably best to replace it.
Old Sep 9, 2004 | 11:09 PM
92blue's Avatar
Former Sponsor
Car: 1992 Camaro RS
Engine: Yet another 350 TPI
Transmission: Borg Warner 6 spd
That sounds like the problem I had. Pulled the 305 out, pulled water pump off and set it aside. Installed 350 and put the pump on it 3 days later. I go to put coolant in the radiator, and it poured all my Dex-Cool right onto the pavement!
Replace it. I don't think theres anything you can do that is worth the effort to fix it. you can buy a new water pump w/ lifetime replacement for $28 at AutoZone in the event you are dead broke like I was when it happened to me.
evilstuie
Jan 9, 2020 08:29 PM
xxx3man`
Sep 23, 2015 10:37 PM
1985chevydude
Aug 22, 2015 05:36 AM
Dialed_In
Aug 20, 2015 01:45 PM
Winchester1094
Aug 18, 2015 10:23 AM
