do i need chip re-burned?
Old Sep 9, 2004 | 10:18 AM
smokingss's Avatar
ok, within the week i should be able to start my 87 monte SS, i just have to put in the distributor, plugs, plug wires and fuel tank. Then hook up 4-5 wires and turn the key. Its a 350 tpi SD rebuilt engine and t5 tranny. I have a modified computer already(basically stock program), i bought a modified stand-alone Speed density harness, and the guy programmed the ecm for a 350 , t5, and removed Vats. However im thinking I may need more of a custom program. I installed full length heades and a K&N filter right on the throttle body, and i heard that SD is not as forgiving as MAF and needs re-buring for most mods. I also removed the air pump and air select/diverter vales. instead, i installed dual 3" regular cats(no AIR tubes). I'm still running the EGR valve and the charcoal canister(purge).
SO... i need to know if i need to have my comp reprogrammed for the headers, K&N, and emissions changes, and if so, IS there anyone who could do it for me? i'll pay, thats not a problem. let me know Thanks in advance. -Paul
_________________
Old Sep 9, 2004 | 10:34 AM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
You've done nothing signifigant to require a change in programming...that said, you could probably squeeze some more out of it with tuning in the chip...again, though with just exhaust, the ECM will compensate for fuel mixture.
Old Sep 9, 2004 | 10:40 AM
smokingss's Avatar
ok, i just wanted to make sure the headers and k&n wouldnt need any changes. Its not going to be my car, once its up and running, it being "sold" to my gf, the whole reason i built it. So i'm not looking for every little hp, its just going to be her daily driver. I want to get it done and out of my garage so i can start on my cars once again.
Linson
Oct 24, 2025 02:00 PM
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Gunner242
Dec 25, 2015 04:49 PM
KO1
16
Oct 15, 2015 05:00 PM
jaridjohn
Oct 5, 2015 07:01 AM
