Hot Cam in l98 problems
Old Sep 11, 2004 | 07:25 PM
code8's Avatar
Car: 87IROC
Engine: 350tpi
I just had my engine rebuilt and put a hot cam in it. The problem is, it runs like a slug.I can't even spin the tires when I mat it.
I have put the timing at 6 and 8 degrees and there is no difference.
One thing I noticed is it is running really rich.
Any suggestions?
Old Sep 11, 2004 | 08:45 PM
TheGreatJ's Avatar
Car: 91Z, 91RS, '84 Jimmy
Engine: L98, 355, L98
Transmission: 700R, T56, 700R4
Re: Hot Cam in l98 problems
Originally posted by code8
Any suggestions?
Tuning?
No major mod will show it's true potential without appropriate tuning. Cams and heads especially will change the needs of the engine. With that particular cam, you'll also notice a fair gain from a higher-stall torque converter, and deeper gears if you don't have them already.
Old Sep 11, 2004 | 09:47 PM
thunderstick's Avatar
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
what he said... i'm getting ready to put that same cam in my L98, and stall was the first thing to come up on the subject. i was told that i would need a 2400-2700 stall. did you have anything done to your trans at all? mine's being rebuilt "corvette style" plus adding another cooler to it. won't know what all this is gonna do for a few more weeks, but i'm just sharing with you what was told to me. i was also told that a converter from a '94 S-10 would make for a real nice launch with my set-up... supposedly has about a 2200 stall. not sure if i'm gonna go that route yet. news ay 11 if i do.
KAM
Old Sep 12, 2004 | 01:35 AM
code8's Avatar
Car: 87IROC
Engine: 350tpi
I'm going to take it to a shop to have it tuned properly.The trans is stock and I'm running 3.27 rear gears.
Is the 94 s10 converter the same size?And is that out of a v6 or 4cyl?
Old Sep 12, 2004 | 06:30 AM
Car: '91 Z28
Axle/Gears: 323's
stock, out of a V-6. same size. you probably need to consider another trans cooler, too. a higher stall is gonna produce even more heat.
KAM
Old Sep 12, 2004 | 11:47 AM
code8's Avatar
Car: 87IROC
Engine: 350tpi
theurge
Aug 21, 2015 12:46 PM
1988iroc350tpi
Aug 14, 2015 07:52 PM
Fronzizzle
Aug 9, 2015 01:15 PM
anesthes
Aug 8, 2015 09:37 PM
