wire loom & vacuum lines
Old Sep 11, 2004 | 07:54 PM
vortec77's Avatar
Car: 86 T/A
Engine: 2000 TPI 5.7L vortec L31
Hey guys, I finally dropped my motor in my 86 T/A today . Its finally starting to come together after almost 2yrs. I just need to ask what size vacuum lines and how long are the sections or lengths of lines that i will need. Im converting from carb to TPI and i have the new painless wiring harness installed and i need to know what sizes of wire loom to get to cover the wiring harness. I have been told i can get all this at pep boys, but i just need to know the sizes from all u guys whove done this before. Thanks,
Old Sep 11, 2004 | 09:41 PM
thunderstick's Avatar
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
my suggestion is to estimate your lengths and get several feet of each. reason i say that is cuz you are gonna need different sizes of each and you don't want to be short. vac line is cheap. wire loom can be a little much. i'm getting ready to put my engine back in in a couple of weeks and i did a lot of rerouting, so most of my wiring can't be completed until the engine goes in. i plan on ordering several different sizes of each so i only have to do it once. you will probably have several "tee's" in your wiring, so hard to say from here.
Old Sep 12, 2004 | 08:04 AM
vortec77's Avatar
Car: 86 T/A
do u know the actual sizes of vacuum lines? 1/4'' 5/8 1inch etc.?
Infested
May 22, 2018 11:56 PM
theshackle
Mar 5, 2017 06:37 PM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
apie2546
Aug 10, 2015 05:43 PM
