best upgraded fuel pump
Old Sep 15, 2004 | 10:41 AM
Ruiny's Avatar
Car: 86 trans am
Transmission: T 56
What would be a good choice for a new fuel pump for my 86 TA with a 350ci. It need to be good for about 400-450 hp
(This is not needed yet but I like the buy once buy right)
Also what is the stock pump good to HP wise?
Old Sep 15, 2004 | 12:46 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
A new Walbro tank would work. They are more of a high volume pump. The stock pump is not rated at horsepower really. You start to lose out because of fuel pressures and not getting enough gas to the rails. Walbro makes Holley's pumps also. They are usually between $120-150 in tank. Carefull not to damage the sending unit when you are pulling the whole unit from the tank.
Old Feb 7, 2005 | 04:20 PM
86BirdSE's Avatar
Car: 1986 Pontiac Firebird S/E
Engine: LG4 TPI Conversion
Axle/Gears: 3.42 SLP Posi 10 Bolt
Bought a new one for a 1989 Turbo Trans-Am 3.8L. It flows more than a v8 tpi pump, and cost about $65 at Napa.
Old Feb 7, 2005 | 10:29 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Part number please, this is worth looking at.
Old Feb 23, 2005 | 09:59 AM
davekrone's Avatar
how hard will it be to replace the fuel pump? what are the procedures?
Old Feb 23, 2005 | 04:14 PM
IROC315's Avatar
Car: 01 Z28 and 89 Iroc
Engine: ls1 fti 3600,S60 w/3:73 gears
Transmission: A4
Axle/Gears: 3:23
Not bad. Do you have flow numbers for that pump? I've also read in a few mags about using a 90s model Vortech truck pump. Can anyone shed some light on this?
Old Feb 23, 2005 | 04:50 PM
92BLKL98's Avatar
Car: 1992 Black Z28 Hardtop
Axle/Gears: 2002 10 bolt w/3:23
http://www.autoperformanceengineering.com/ Nuff said, Hard to beat their prices and service for a good Hi Perf. pump. They also give all the hot poop on all their pumps
Old Feb 23, 2005 | 05:07 PM
IROC315's Avatar
Transmission: A4
Axle/Gears: 3:23
Wow, thanks for that link man. I'd never heard of them. Good prices.
Old Feb 24, 2005 | 02:57 PM
MikeH's Avatar
Car: 90 IROC
Engine: 406
Transmission: GMPP 93/4L60
Axle/Gears: 9 bolt 3.27
I bought a 255 walbro from them about 4 years ago. And its worked great no problems
Old Feb 24, 2005 | 03:04 PM
87Formula4bbl's Avatar
Car: '87 Formula
I went in to Autozone and looked through their fuel pump book, came out with a stock pump for a newer model truck (CK1500 maybe, dont remember exactly) but when comparing it to the stock TPI pump it flowed about 75% more and put out something like 90 psi compared to the stock 65 or so. It's been a while like I said, but it would be a great, cheap(er than walbro) upgrade. Lifetime warranty too.
Old Feb 24, 2005 | 03:26 PM
Lo-tec's Avatar
Car: clapped out 84Z
Engine: 355 efi roller
Transmission: tremec TKO
Check out this kit. It uses a walbro pump:
http://www.racetronix.com/product/RX..._Pump_Kit.html
Old Feb 26, 2005 | 12:26 AM
qwik86iroc's Avatar
Car: Guess!
Engine: 350 Stealth Ram, Supercharged
Transmission: 700R4 / 3.73
Granatoli makes a good pump.
Glowsock
Jul 24, 2025 03:15 PM
Frozer!!!
Jan 19, 2024 04:55 PM
92camaroJoe
Jul 29, 2023 07:57 PM
gta90
Sep 15, 2015 04:00 PM
92camaroJoe
Aug 13, 2015 06:07 AM
